Home » Newcomers » Newcomers » Guidelines(UML for eclipse)
icon5.gif  Guidelines [message #654324] Tue, 15 February 2011 03:02 Go to next message
nikola vulovic is currently offline nikola vulovic
I am looking for uml thats easy to install/use for eclipse.
I am using Eclipse SDK Version: 3.5.2 galileo installed via sofware center in ubuntu 10.10.
I have seen many uml rated stuff for eclipse and tryed few things, none have let me even make an uml model.
What do i need to do in order to make uml model which can be made to java code and vice versa like in netbeans.
TY VM for any info.
Re: Guidelines [message #654397 is a reply to message #654324] Tue, 15 February 2011 10:06 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
> TY VM for any info.
First suggestion, don't install Eclipse from any Linux package manager;
go to http://www.eclipse.org/downloads and get the latest version right
from the source. Also make sure you've installed the Sun/Oracle JDK and
point Eclipse to it, as described in http://wiki.eclipse.org/Eclipse.ini
Then, you might want to ask about UML on the UML Tools forum group.
Eric
icon5.gif  Re: Guidelines [message #654465 is a reply to message #654397] Tue, 15 February 2011 17:13 Go to previous messageGo to next message
I should install Eclipse IDE for Java Developers, right?
Re: Guidelines [message #654647 is a reply to message #654465] Wed, 16 February 2011 10:02 Go to previous message
Since you're specifically asking about UML, I would think that the
Modeling Tools package would be the most appropriate. But don't worry,
you can always add more features to whatever package you install.
Eric
Previous Topic:Having trouble importing a WSDL file
Next Topic:BIRT meanings/uses of advanced properties
Current Time: Sat May 18 19:16:12 EDT 2013
Powered by FUDForum. Page generated in 0.01823 seconds
