Any suggestion to create flow chart diagram? [message #652666] |
Fri, 04 February 2011 20:03  |
Charles Messages: 4 Registered: July 2009 |
Junior Member |
Hi All,
I would like to create a diagram tool in Eclipse which is similar to flow chart diagram so that user can easily manage their data flow. I also want to keep the minimum set of the Eclipse plugins and make some modifications for the flow chart behaviors. Because it's time-consuming to create a new one from scratch, is there any Eclipse project or component doing this? Or how to build a tool which can create sequence diagram using some data?
Thanks in advance.
Charles
[Updated on: Tue, 08 February 2011 06:08] Report message to a moderator
| Re: Any suggestion to create flow chart diagram? [message #766570 is a reply to message #652815] |
Thu, 15 December 2011 21:12  |
loic Missing name Messages: 6 Registered: December 2011 |
Junior Member |
Hi Mickael,
What do you mean by "all the BPM / BPMN stuff" ? I looked at JWT and BPMN plugins, but none seem to provide an extension point to their editor (maybe I missed it).
I am looking at a simple BPMN-like editor for my own Eclipse plugin.
Any advice or pointer where I should look at ?
Thanks!
FUDForum. Page generated in 0.04463 seconds
