Home » Eclipse Projects » EGit / JGit » Share a project and create a repo
Share a project and create a repo [message #652407] Thu, 03 February 2011 18:23 Go to next message
Paul Webster is currently offline Paul WebsterFriend
I'm trying to figure out how to use EGit to share a project effectively.
1) share the project ... that creates a <project>/.git directory.
2) create a new bare repository somewhere
3) push from the project repo to the new bare repo
4) delete the project and clone from the new repo
Does that sound about right?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Share a project and create a repo [message #652491 is a reply to message #652407] Fri, 04 February 2011 09:45 Go to previous messageGo to next message
Manuel Doninger is currently offline Manuel DoningerFriend
Paul Webster wrote on Thu, 03 February 2011 13:23
This step is not necessary.
Re: Share a project and create a repo [message #652530 is a reply to message #652491] Fri, 04 February 2011 12:34 Go to previous messageGo to next message
Based on my steps, I can't now select the project and then use push ...
is there another step necessary?
In step #3 I use the Git Repo Explorer to push from the project repo to
the bar repo.
PW
Paul Webster
Re: Share a project and create a repo [message #652648 is a reply to message #652407] Fri, 04 February 2011 20:25 Go to previous messageGo to next message
You have to configure the bare repository as remote at your local repository. Then the Push command in the Team menu should work.
Re: Share a project and create a repo [message #652864 is a reply to message #652648] Mon, 07 February 2011 12:28 Go to previous messageGo to next message
If I configure push and fetch to point to the bare repo (after I've
pushed the first time) it looks OK in the git repo explorer, but
selecting push to upstream or pull on my project generates an error
about some property not being set. I'll reproduce later today and open
a bug report.
PW
Paul Webster
Re: Share a project and create a repo [message #652902 is a reply to message #652864] Mon, 07 February 2011 13:58 Go to previous message
Opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=336504
PW
Paul Webster
Previous Topic:JGit - What are all these entries in DirCache?
Next Topic:Updte site dind't work
Current Time: Mon Feb 19 16:40:35 GMT 2018
Powered by FUDForum. Page generated in 0.01561 seconds
