Home » Modeling » EMF » [CDO] Problems loading objects from a resource
[CDO] Problems loading objects from a resource [message #651989] Wed, 02 February 2011 11:18 Go to next message
Originally posted by: info.dav85.de
Hi everyone,
i've got some problems while loading objects from a resource. In my case
i create a new resource with a CDOTransaction and than i add some
objects and do a commit. All works fine, i can work with the resource
and the containing objects. Then i restart my application and try load
my created resource. The resource is loaded by the CDOTransaction. After
that i will get some objects from the resource like:
resource.getContents().get(0);
and then i got the following exception:
!STACK 0
org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally
not available: CDOPackageUnit[id=MY_PACKAGE_URI, state=PROXY,
type=UNKNOWN, originalType=NATIVE, timeStamp=02.02.2011 12:08:52:718]
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPack ages(CDOSessionImpl.java:503)
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .load(CDOPackageUnitImpl.java:250)
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .load(CDOPackageUnitImpl.java:239)
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:118)
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:105)
Is there problem with my modelconfiguration or the PackageRegistry??
Thanks a lot!
David
Re: [CDO] Problems loading objects from a resource [message #652008 is a reply to message #651989] Wed, 02 February 2011 12:07 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 02.02.2011 12:18, schrieb David Hein:
> Hi everyone,
> i've got some problems while loading objects from a resource. In my case i create a new resource with a CDOTransaction and than i add some objects and do a commit. All works fine, i can work with the resource and the containing objects. Then i restart my application and try load my created resource. The resource is loaded by the CDOTransaction. After that i will get some objects from the resource like:
> !STACK 0
> org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally not available: CDOPackageUnit[id=MY_PACKAGE_URI, state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=02.02.2011 12:08:52:718]
> at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPack ages(CDOSessionImpl.java:503)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .load(CDOPackageUnitImpl.java:250)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .load(CDOPackageUnitImpl.java:239)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:118)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:105)
Both can be possible. Is your generated package properly deployed on the client? is it properly registered (proper nsURI, etc...)?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Problems loading objects from a resource [message #652013 is a reply to message #652008] Wed, 02 February 2011 12:26 Go to previous messageGo to next message
Am 02/02/2011 13:07, schrieb Eike Stepper:
>> Hi everyone,
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Yes the model is deployed on the client and the PackageRegistry has all
my packages registered. I found all of my URIs.
If i create a new second resource with containing objects from my model
and do a commit then i'm able to load my first created resource and
objects. Do i a restart again, i can't load this two resources with
their objects.
It seems that after a commit the package are known?! What can i do that
the packages are known after a new start of my application or what does
the commit what i do not?
Thanks.
Re: [CDO] Problems loading objects from a resource [message #652016 is a reply to message #652013] Wed, 02 February 2011 12:53 Go to previous messageGo to next message
Am 02/02/2011 13:26, schrieb David Hein:
>>> Hi everyone,
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>> Cheers
>> /Eike
> their objects.
> Thanks.
I have done another tests with other models in my application. All the
other models works fine. The problem occurred only with this one model.
This model has a reference to an another model. Can this be a problem?
I will do a test wihout this reference and hope to find the mistake :)
Re: [CDO] Problems loading objects from a resource [message #652022 is a reply to message #652016] Wed, 02 February 2011 13:07 Go to previous messageGo to next message
Am 02.02.2011 13:53, schrieb David Hein:
> I have done another tests with other models in my application. All the other models works fine. The problem occurred only with this one model. This model has a reference to an another model. Can this be a problem?
I'm not aware of problems with interrelated generated packages, but that does not mean there are none.
One thing that used to create problems is a package with no concrete classes in it. CDO needs to instantiate an arbitrary class to see if the instance can be cast to InternalCDOObject.
Cheers
/Eike
Re: [CDO] Problems loading objects from a resource [message #652285 is a reply to message #652022] Thu, 03 February 2011 13:13 Go to previous messageGo to next message
Am 02/02/2011 14:07, schrieb Eike Stepper:
>> problem?
> Cheers
> /Eike
Hello again
I have found the reason for this problem.
My model is not instantiated during loading objects from the resource.
If i call MYMODELPACKAGE.eInstance before i do this, all works fine and
my package is found.
At the moment it is a workaround for me. Why does not (can not) EMF
instantiate the model by itself?
Thanks.
Re: [CDO] Problems loading objects from a resource [message #652289 is a reply to message #652285] Thu, 03 February 2011 13:29 Go to previous messageGo to next message
Am 03.02.2011 14:13, schrieb David Hein:
> Hello again
> My model is not instantiated during loading objects from the resource. If i call MYMODELPACKAGE.eInstance before i do this, all works fine and my package is found.
I'm glad to hear this.
Not sure if that's a workaround. Without OSGI you are expected to do manually what the extension registry would do for you if you were running in OSGi.
> Why does not (can not) EMF instantiate the model by itself?
I recommend you ask this question again in a new thread without "[CDO]". More liekly that the EMF gurus see it then ;-)
Cheers
/Eike
Re: [CDO] Problems loading objects from a resource [message #736745 is a reply to message #652289] Fri, 14 October 2011 09:38 Go to previous messageGo to next message
Federico Tomassetti is currently offline Federico TomassettiFriend
I have the same problem BUT the package not found is not one built by me, it seems something related to CDO:
Caused by: org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally not available: CDOPackageUnit[id=http://www.eclipse.org/emf/CDO/Eresource/4.0.0, state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=2011-10-14 11:32:20.183]
Re: [CDO] Problems loading objects from a resource [message #736764 is a reply to message #736745] Fri, 14 October 2011 10:05 Go to previous messageGo to next message
Am 14.10.2011 11:38, schrieb Federico Tomassetti:
That is a CDO system package (included in org.eclipse.emf.cdo). If that's not available your setup is probably wrong. If
you're running standalone (no extension registy available) you may have to manually register this package with the
global package registry, e.g.:
EresourcePackage.eINSTANCE.getClass();
If that works, we could consider to do that for all system packages somewhere in the client core.
Cheers
/Eike
Re: [CDO] Problems loading objects from a resource [message #736770 is a reply to message #736764] Fri, 14 October 2011 10:11 Go to previous messageGo to next message
It works now.
I will look at that because on another Eclipse installation that worked without manually register the packages.
Federico
Re: [CDO] Problems loading objects from a resource [message #736781 is a reply to message #736770] Fri, 14 October 2011 10:23 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Am 14.10.2011 12:11, schrieb Federico Tomassetti:
<blockquote cite="mid:j7915f$u9n$1@news.eclipse.org" type="cite">It
works now.
<br>
<br>
<br>
</blockquote>
Yeah, I've never heard before that manual registration of our system
packages is required. The reason is probably that the normal setup
code on a client looks like:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<!-- = Java Sourcecode to HTML automatically converted code = -->
<!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3"
cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code>
<font color="#ffffff">    </font><font color="#000000">CDOSession session = openSession</font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">CDOTransaction transaction = session.openTransaction</font><font
<font color="#ffffff">    </font><font color="#000000">CDOResource resource = transaction.getResource</font><font
color="#000000">(</font><font color="#2a00ff">"/my/resource"</font><font
color="#000000">)</font><font color="#000000">;</font></code>
</td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<br>
I guess through that sequence the Eresource package gets registered
implicitely. Can you post the exact sequence of your code that ended
in that exception?<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
Re: [CDO] Problems loading objects from a resource [message #736796 is a reply to message #736781] Fri, 14 October 2011 10:42 Go to previous messageGo to next message
this is the line:
CDOResource rootResource = view.getRootResource();
Stack trace:
java.lang.RuntimeException: Problem operation on view: Generated packages locally not available: CDOPackageUnit[id=http://www.eclipse.org/emf/CDO/Eresource/4.0.0, state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=2011-10-14 11:32:20.183]
	at it.rcpvision.cdoexamples.stockmanager.client.SessionOperator.doWithView(SessionOperator.java:34)
	at it.rcpvision.cdoexamples.stockmanager.client.NavigationPanel.updateListOfResources(NavigationPanel.java:276)
	at it.rcpvision.cdoexamples.stockmanager.client.NavigationPanel.connected(NavigationPanel.java:261)
	at it.rcpvision.cdoexamples.stockmanager.client.ClientGUI.connected(ClientGUI.java:57)
	at it.rcpvision.cdoexamples.stockmanager.client.ClientGUI.access$3(ClientGUI.java:54)
	at it.rcpvision.cdoexamples.stockmanager.client.ClientGUI$2.widgetSelected(ClientGUI.java:114)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4125)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3971)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
	at it.rcpvision.cdoexamples.stockmanager.client.ClientGUI.createGUI(ClientGUI.java:83)
	at it.rcpvision.cdoexamples.stockmanager.client.ClientGUI.main(ClientGUI.java:26)
	at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPackages(CDOSessionImpl.java:526)
	at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:250)
	at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:239)
	at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.doGetEPackage(CDOPackageInfoImpl.java:123)
	at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:110)
	at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:105)
	at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:133)
	at org.eclipse.emf.cdo.common.model.CDOClassifierRef.resolve(CDOClassifierRef.java:110)
	at org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDOClassifierRefAndResolve(CDODataInputImpl.java:167)
	at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.readSystemValues(BaseCDORevision.java:145)
	at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.read(BaseCDORevision.java:131)
	at org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:482)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readRevision(RevisionInfo.java:193)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:145)
	at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:143)
	at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:1)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:90)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:123)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:103)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:51)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:433)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:496)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:529)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.loadRevisions(CDOClientProtocol.java:166)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:365)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:276)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:259)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:252)
	at org.eclipse.emf.internal.cdo.view.CDOViewImpl.getRevision(CDOViewImpl.java:653)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:796)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:706)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:675)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getRootResource(AbstractCDOView.java:216)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getRootResource(AbstractCDOView.java:1)
	at it.rcpvision.cdoexamples.stockmanager.client.NavigationPanel.getOrCreateStocksResource(NavigationPanel.java:356)
	at it.rcpvision.cdoexamples.stockmanager.client.NavigationPanel.access$6(NavigationPanel.java:352)
	at it.rcpvision.cdoexamples.stockmanager.client.NavigationPanel$6.execute(NavigationPanel.java:282)
	at it.rcpvision.cdoexamples.stockmanager.client.SessionOperator.doWithView(SessionOperator.java:32)
	... 16 more
Strangely when I run some tests which write into the CDO repository everything works fine but it is probably because it is easy to have the package implicitly registered (I think it it enough that the class is loaded: there is some static initializer performing the registration).
Re: [CDO] Problems loading objects from a resource [message #736819 is a reply to message #736796] Fri, 14 October 2011 11:08 Go to previous messageGo to next message
Am 14.10.2011 12:43, schrieb Federico Tomassetti:
The code of this method would be interesting. I suspect the first call to CDO is made there.
Exactly.
Cheers
/Eike
Re: [CDO] Problems loading objects from a resource [message #736831 is a reply to message #736819] Fri, 14 October 2011 11:19 Go to previous messageGo to next message
Eike Stepper wrote on Fri, 14 October 2011 13:08
Yes the exception is thrown by the view.getRootResource call inside this method:
	private CDOResource getOrCreateStocksResource(CDOView view)
			throws CommitException {
		// FIXME transaction.getOrCreateResource....
		CDOResource stocksResource = null;
		for (EObject content : rootResource.getContents()) {
			if (content instanceof CDOResource) {
				CDOResource containedResource = (CDOResource) content;
				if (containedResource.getPath().equals(STOCKS_RESOURCE_PATH)) {
					stocksResource = containedResource;
		if (null == stocksResource) {
			createResource(STOCKS_RESOURCE_PATH);
			return getOrCreateStocksResource(view);
		return stocksResource;
Re: [CDO] Problems loading objects from a resource [message #736833 is a reply to message #736831] Fri, 14 October 2011 11:21 Go to previous messageGo to next message
Am 14.10.2011 13:19, schrieb Federico Tomassetti:
I see. Please submit a bugzilla and I'll see what I can do ;-)
Cheers
/Eike
icon3.gif  Re: [CDO] Problems loading objects from a resource [message #787676 is a reply to message #652285] Tue, 31 January 2012 21:28 Go to previous messageGo to next message
Alexandre Borgoltz is currently offline Alexandre BorgoltzFriend
FYI, I have encountered the exact same behaviour.
The reason was simple : I was missing the org.eclipse.emf.ecore.generated_package extension.
Or more precisely, I had it but the mentioned NS URI was wrong. (Maybe you incremented the version number in the namespace in the .ecore but forgot to update plugin.xml?)
   <extension point="org.eclipse.emf.ecore.generated_package">
      <package
            uri="http://some/wrong/URI"
            class="my.application.MyPackage"
            genModel="model/my-model.genmodel"/>
   </extension>
HTH!
Smile
Alexandre
Re: [CDO] Problems loading objects from a resource [message #912392 is a reply to message #787676] Thu, 13 September 2012 13:36 Go to previous message
Mark Rowe is currently offline Mark RoweFriend
Another possibility is that the model package is not being registered in openSession().
This happened to me because I was using the QuickStartTest.java class as a boiler plate without changing the BaseTest.java class.
Specifically the line:
cdoSession.getPackageRegistry().putEPackage(CompanyPackage.eINSTANCE);
Needs to be updated to register your model package instead of "CompanyPackage".
Previous Topic:(no subject)
Next Topic:[CDO] Example cdo-server.xml for a DB store
Current Time: Wed Jun 20 17:34:58 GMT 2018
Powered by FUDForum. Page generated in 0.03038 seconds
