Home » Language IDEs » ServerTools (WTP) » unable to run JSF application(No org.apache.tomcat.InstanceManager set in ServletContext)
unable to run JSF application [message #651221] Fri, 28 January 2011 13:05 Go to next message
Luca Ferrari is currently offline Luca FerrariFriend
Hi all,
I'm going nuts and I've spent all the morning trying to figure out what's happening withijn my helios configuration since I'm no more able to deploy and run an application on tomcat 6.0.29 having the following exception:
28-Jan-2011 12:56:43 org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /sviluppo/java/jdk1.6.0_23/jre/lib/amd64/server:/sviluppo/java/jdk1.6.0_23/jre/lib/amd64:/sviluppo/java/jdk1.6.0_23/jre/../lib/amd64:/usr/lib64/xulrunner-addons:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
28-Jan-2011 12:56:43 org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.j2ee.server:fascicolopersonale' did not find a matching property.
28-Jan-2011 12:56:43 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
28-Jan-2011 12:56:43 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1071 ms
28-Jan-2011 12:56:43 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
28-Jan-2011 12:56:43 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.29
28-Jan-2011 12:56:44 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/sviluppo/java/eclipseWorkspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/fascicolopersonale/WEB-INF/lib/servlet-api.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
28-Jan-2011 12:56:44 org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener "com.sun.faces.config.ConfigureListener" is already configured for this context. The duplicate definition has been ignored.
28-Jan-2011 12:56:44 com.sun.faces.config.rules.NavigationRuleRule end
WARNING: [NavigationRuleRule]{faces-config/navigation-rule} Merge(/main.jsp)
WARNING: [NavigationRuleRule]{faces-config/navigation-rule} Merge(/titles.jsp)
28-Jan-2011 12:56:44 org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
28-Jan-2011 12:56:44 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
28-Jan-2011 12:56:45 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/64  config=null
28-Jan-2011 12:56:45 org.apache.catalina.startup.Catalina start
INFO: Server startup in 1334 ms
28-Jan-2011 12:56:45 org.apache.catalina.core.ApplicationDispatcher invoke
SEVERE: Servlet.service() for servlet jsp threw exception
java.lang.IllegalStateException: No org.apache.tomcat.InstanceManager set in ServletContext
	at org.apache.jasper.runtime.InstanceManagerFactory.getInstanceManager(InstanceManagerFactory.java:39)
	at org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:160)
	at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:353)
	at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:389)
	at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:332)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
	at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
	at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
	at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
	at com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:346)
	at com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:152)
	at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:107)
	at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:268)
	at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:137)
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:214)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
	at java.lang.Thread.run(Thread.java:662)
28-Jan-2011 12:56:45 org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet Faces Servlet threw exception
The problem is I cannot figure out what changed in the project configuration, run-time or classpath since I have only worked on code and not on configuration. However I tried to setup another web project deployed on the same tomcat machine and it works fine, so the problem must be on the project itself. However, how can I figure it out?
[Updated on: Fri, 28 January 2011 13:05]
Report message to a moderator
Re: unable to run JSF application [message #651234 is a reply to message #651221] Fri, 28 January 2011 13:37 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
On 1/28/2011 8:05 AM, Luca Ferrari wrote:
> Hi all,
> exception:
> java.library.path:
> /sviluppo/java/jdk1.6.0_23/jre/lib/amd64/server:/sviluppo/ja va/jdk1.6.0_23/jre/lib/amd64:/sviluppo/java/jdk1.6.0_23/jre/ ../lib/amd64:/usr/lib64/xulrunner-addons:/usr/java/packages/ lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
> begin
> validateJarFile
> INFO:
> validateJarFile(/sviluppo/java/eclipseWorkspace/.metadata/.p lugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/fascicolo personale/WEB-INF/lib/servlet-api.jar)
> Merge(/main.jsp)
> Merge(/titles.jsp)
> Merge(/main.jsp)
> Merge(/main.jsp)
> at
> org.apache.jasper.runtime.InstanceManagerFactory.getInstance Manager(InstanceManagerFactory.java:39)
> at
> org.apache.jasper.servlet.JspServletWrapper.getServlet(JspSe rvletWrapper.java:160)
> at
> org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:353)
> at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:389)
> at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :332)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.apache.catalina.core.ApplicationDispatcher.invoke(Applic ationDispatcher.java:646)
> at
> org.apache.catalina.core.ApplicationDispatcher.processReques t(ApplicationDispatcher.java:436)
> at
> org.apache.catalina.core.ApplicationDispatcher.doForward(App licationDispatcher.java:374)
> at
> org.apache.catalina.core.ApplicationDispatcher.forward(Appli cationDispatcher.java:302)
> at
> com.sun.faces.context.ExternalContextImpl.dispatch(ExternalC ontextImpl.java:346)
> at
> com.sun.faces.application.ViewHandlerImpl.renderView(ViewHan dlerImpl.java:152)
> at
> com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderRe sponsePhase.java:107)
> at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:268)
> at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.j ava:137)
> at javax.faces.webapp.FacesServlet.service(FacesServlet.java:21 4)
> at
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:857)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:588)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:489)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
I believe InstanceManagerFactory is new in Tomcat 7.0.x. So it appears
that in addition to servlet-api.jar being included in the published
project's WEB-INF/lib (which should never be included), there could be
other jars which should also not be there. One, possibly with "jasper"
in its name, could be causing this exception. You should check the
project's configuration to see why the inappropriate jar(s) are being
included.
Larry
Re: unable to run JSF application [message #665530 is a reply to message #651221] Thu, 14 April 2011 23:08 Go to previous messageGo to next message
oprogfrogo  is currently offline oprogfrogo Friend
I'm having the exact same problem. Help!
Re: unable to run JSF application [message #665694 is a reply to message #665530] Fri, 15 April 2011 13:40 Go to previous message
Does your console output also include "- jar not loaded. See Servlet
Spec 2.3, section 9.7.2. Offending class: ..." as in the original post.
If so, see my earlier answer to the original post. Otherwise you will
need to provide your own details.
Larry
Previous Topic:Local Rhino Debugging
Next Topic:JavaScript debugging in Helios
Current Time: Sun May 20 12:19:34 GMT 2018
Powered by FUDForum. Page generated in 0.01873 seconds
