| Failed to install Web Tools plugin [message #649903] |
Thu, 20 January 2011 16:49  |
Originally posted by: m_lehmeier.gmx.de
Hello.
I use Eclipse Helios.
Version: Helios Service Release 1
Build id: 20100917-0705
I downloaded Eclipse with the Modeling Tools package but now need to do
some web development, too.
I added the update site http://download.eclipse.org/webtools/updates
But I get a dependency problem when trying to install the Eclipse Java
EE Developer Tools and the Eclipse Web Developer Tools.
It tells me:
WTP J2EE UI Plug-in 1.1.301.v201001252130 (org.eclipse.jst.j2ee.ui
1.1.301.v201001252130) requires 'bundle com.ibm.icu [3.4.4,4.1.0)' but
it could not be found
It seems that other people had similar problems which supposedly were
fixed months ago.
I looked but have no idea where I can get this com.ibm.icu plugin.
Can anybody help me?
Thanks!
Lehmeier Michael
| Re: Failed to install Web Tools plugin [message #649944 is a reply to message #649926] |
Fri, 21 January 2011 01:39   |
On 2011-01-21, Nitin Dahyabhai <nitind@us.ibm.com> wrote:
> On 1/20/2011 4:49 PM, Michael Lehmeier wrote:
> The correct update site for WTP with Helios is the Helios update site
> itself.
Okay, I thought this alternate site was the correct one since I couldn't
get the plugin from the Helios update site to work.
When I try to configure Server->Runtime Environments there is a "J2EE
Runtime Library" predefined.
I can't use this to create a Dynamic Web Project: "Runtime 'J2EE Runtime
Library' is invalid."
So I try to add a Tomcat installation.
The "New Server Runtime Environment" doesn't show me any options besides
the J2EE Runtime Library. "Download additional server adapters" doesn't
help, there doesn't seem to be an adapter for Tomcat. The "Create a new
local server" checkbox vanishes when I click on it. (That can't be
right)
So I do what I tried to do first:
I opened the "Search for Runtime Environments" and pointed to the Tomcat
installation directory (apache-tomcat-7.0.6) but get "no new server
runtime environments were found".
From that point I didn't know any alternatives.
What did I do wrong?
Lehmeier Michael
| Re: Failed to install Web Tools plugin [message #650125 is a reply to message #649944] |
Fri, 21 January 2011 14:49   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
>> itself.
> right)
If you tried to install WTP in pieces, like adding "Eclipse Java
EE Developer Tools" and the "Eclipse Web Developer Tools", then you
would not install the bulk of the JST Server support. I'll admit it's
not clear what "Eclipse Java EE Developer Tools" is and isn't. To
install the JST Server support for Tomcat, install the "JST Server
Adapters 3.2.2.v20100818b-777HFGRCcNBDiBjIbhBA8". The other "JST
Server Adapters 3.2.0.v201005241530-208Z7w31211419" installs the J2EE
Preview server support that uses the copy of Jetty built into Eclipse.
Larry
| Re: Failed to install Web Tools plugin [message #650128 is a reply to message #650125] |
Fri, 21 January 2011 15:06  |
That did it!
Thank you!
Lehmeier Michael
FUDForum. Page generated in 0.01520 seconds
