Home » Archived » M2M (model-to-model transformation) » ATL- SCA empty output file (Transformation BPMN 2.0 to SCA 1.0)
ATL- SCA empty output file [message #649843] Thu, 20 January 2011 17:49 Go to next message
Alex  is currently offline Alex Friend
I am new to ATL language, and I ran successfully ATL eclipse examples on eclipse.
Now, I am trying to make a M2M transformation BPMN 2.0 to SCA 1.0
I am using:
- eclipse Helios and ATL 3.1.1
- BPMN 2.0 Ecore metamodel provided by BPMN2 project
obtained from http://git.eclipse.org/c/bpmn2
- A part of SCA 1.0 Ecore metamodel generated from XSD metamodel provided by osoa.
Here my simple code ATL:
-- @path sca=/BPMN2SCA/metaModels/sca.ecore
-- @path bpmn2=/BPMN2SCA/metaModels/bpmn2.ecore
module BPMN2SCA;
create ExampleSCA : sca from ExampleBPMN : bpmn2;
rule DefinitionsToComposite {
from
col: bpmn2!Definitions
to
com: sca!Composite(
My SCA Ecore metamodel:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="sca">
<eClassifiers xsi:type="ecore:EClass" name="Composite">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" ordered="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
My simple BPMN 2.0 example:
<?xml version="1.0" encoding="ISO-8859-1" standalone="yes"?>
<semantic:definitions id="_1275488606936"
targetNamespace="http://www.trisotech.com/definitions/_1275488606936"
xmlns:di="http://www.omg.org/spec/DD/20100524/DI"
xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI"
xmlns:dc="http://www.omg.org/spec/DD/20100524/DC"
xmlns:semantic="http://www.omg.org/spec/BPMN/20100524/MODEL">
</semantic:definitions>
I just want to make a first step, is something wrong in my ATL code ? because I get an empty output SCA file like this:
Thanks a lot for your help
Alex
[Updated on: Thu, 20 January 2011 17:56]
Report message to a moderator
Re: ATL- SCA empty output file [message #649959 is a reply to message #649843] Fri, 21 January 2011 08:25 Go to previous messageGo to next message
Vincent MAHE is currently offline Vincent MAHEFriend
Le 20/01/2011 18:50, Alex a écrit :
> Hello,
> I am new to ATL language and I am trying to make a M2M transformation
> BPMN 2.0 to SCA 1.0
> I am using:
> - BPMN 2.0 Ecore metamodel provided by BPMN2 project obtained from
> provided by osoa.
> module BPMN2SCA;
> from
> to com: sca!Composite(
> xmlns:xmi="http://www.omg.org/XMI"
> </eClassifiers>
> </ecore:EPackage>
This seems to be an empty model, so you obtain a corresponding empty SCA
model, no ??
> Alex
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: ATL- SCA empty output file [message #649964 is a reply to message #649959] Fri, 21 January 2011 09:01 Go to previous messageGo to next message
First, Thank you for your reply.
Yes it's an empty BPMN Model, but I have an ATL code which transform a Definitions to a composite.I supposed to obtain an SCA model like this
<composite xmlns="http://www.osoa.org/xmlns/sca/1.0" >
</composite>
Thank you for your cooperation
Alex
Re: ATL- SCA empty output file [message #649973 is a reply to message #649964] Fri, 21 January 2011 09:13 Go to previous messageGo to next message
> </composite>
> Alex
ATL executes rules on "matched" elements. If you have an empty model,
ATL does nothing at all, implying you get an empty XMI file.
Cordialement
Vincent MAHÉ
Re: ATL- SCA empty output file [message #649977 is a reply to message #649973] Fri, 21 January 2011 09:30 Go to previous messageGo to next message
I'll modify my BPMN model and I'll keep you posted.
Thanks.
Alex
Re: ATL- SCA empty output file [message #649980 is a reply to message #649973] Fri, 21 January 2011 09:48 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
Vincent MAHE wrote on Fri, 21 January 2011 04:13
The xmi file isn't empty, it contains one "definitions" element.
Look carefully :
<semantic:definitions id="_1275488606936" ...></semantic:definitions>
Re: ATL- SCA empty output file [message #649988 is a reply to message #649980] Fri, 21 January 2011 10:11 Go to previous message
hello,
It's right, I have one element 'definitions' in my BPMN model that's why I am not supposed to obtain an empty SCA.
Normally, I must obtain an SCA model as an output file:
</composite>
I posted my problem on MDT forum hoping to resolve it.
Thanks for your cooperation
Alex
Previous Topic:[ATL] Using *.profile.uml files
Next Topic:No overriding, but just changing the differences in m2m transformations
Current Time: Tue Apr 24 05:17:11 GMT 2018
Powered by FUDForum. Page generated in 0.02391 seconds
