Home » Eclipse Projects » BIRT » Saving birt output report on server side(Saving birt output report on server side)
Saving birt output report on server side [message #649680] Thu, 20 January 2011 09:55 Go to next message
JIE is currently offline JIEFriend
Hi all,
I'm using birt 2.3.2 to generate PDF report in the Java web application.
I could view the the output PDF in the firefox now, by clicking a button which will forward the request to a JSP page, in which the 'birt:viewer' object is defined.
But I also want to save the PDF into the disk of server side.
I'm thinking of writing a Java class extending ReportEventAdapter(Using afterRender event) and binding it with .rptdesign. But it seems no way to get content of report in java class...
Does anybody know how to do that? Or another solution to save the PDF?
Any information will be appreciated.
Thanks in advance!
Re: Saving birt output report on server side [message #649841 is a reply to message #649680] Thu, 20 January 2011 17:24 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
You can create either a run task or render task in the after render
event handler to do what you want. You could enter a script like this
to do just a render (note example is in JavaScript but could be done in
Java).
rptdoc =
reportContext.getHttpServletRequest().getAttribute("attributeBean ").getReportDocumentName();
importPackage(Packages.org.eclipse.birt.report.engine.api);
var re = reportContext.getReportRunnable().getReportEngine();
var mdocument = re.openReportDocument(rptdoc);
var options = new PDFRenderOption();
options.setOutputFormat("pdf");
options.setOutputFileName("c:/test/mytest.pdf");
var ntask = re.createRenderTask(mdocument);
ntask.setRenderOption(options);
ntask.render();
ntask.close();
This code has no error checking in it. You also may want to put a check
in to see if you are in the designer and not run the code if you are.
reportContext.getHttpServletRequest().getAttribute("attributeBean ").isDesigner();
Here is an example of doing a run and render task:
var des = re.openReportDesign("c:/xfer/burstdetail.rptdesign");
var ntask = re.createRunAndRenderTask(des);
ntask.setParameterValue("CustomerNumber",
this.getRowData().getColumnValue(0).toString() );
var outputfile = "c:/temp/test" + this.getRowData().getColumnValue(0) +
".pdf";
options.setOutputFileName(outputfile);
ntask.run();
ntask.close();
Jason
On 1/20/2011 4:55 AM, JIE wrote:
> Hi all,
> object is defined.
> Thanks in advance!
Re: Saving birt output report on server side [message #649942 is a reply to message #649841] Fri, 21 January 2011 06:19 Go to previous messageGo to next message
Hi Jason,
Thank you very much for your help.
I can do it in Java now Smile
Re: Saving birt output report on server side [message #649979 is a reply to message #649841] Fri, 21 January 2011 09:45 Go to previous messageGo to next message
I've tried the Javascript and it generated the pdf in the disk.
But the pdf cannot be opened (The file is already open or in use by another application.)
Only when the request is changed(I click somewhere else in the application) or shut down the server, can it open.
Do you know why?
Jason Weathersby wrote on Thu, 20 January 2011 12:24
Java).
rptdoc =
ntask.render();
ntask.close();
Re: Saving birt output report on server side [message #650093 is a reply to message #649979] Fri, 21 January 2011 16:55 Go to previous messageGo to next message
Try adding
mdocument.close();
after you close the task.
Jason
> Do you know why?
>> in Java).
>> rptdoc =
>> ntask.render();
>> ntask.close();
>> check in to see if you are in the designer and not run the code if you
>> are.
>> ").isDesigner();
Re: Saving birt output report on server side [message #650260 is a reply to message #650093] Mon, 24 January 2011 02:26 Go to previous messageGo to next message
Still not working...
Re: Saving birt output report on server side [message #650390 is a reply to message #650260] Mon, 24 January 2011 17:13 Go to previous messageGo to next message
Try this (again with no error checking):
mmap =
reportContext.getHttpServletRequest().getAttribute("attributeBean ").getModuleOptions();
rptdoc =
importPackage(Packages.java.io)
var mdocument = re.openReportDocument(null,rptdoc, mmap);
baos = new ByteArrayOutputStream();
options.setOutputStream(baos);
ntask.render();
ntask.close();
mdocument.close();
fout = new FileOutputStream("c:/test/myreport.pdf");
fout.write(baos.toByteArray());
fout.flush()
fout.close();
Jason
Re: Saving birt output report on server side [message #696831 is a reply to message #650390] Thu, 14 July 2011 22:42 Go to previous messageGo to next message
Magg  is currently offline Magg Friend
Hi JIE and Jason. I need to implement this approach in my birt reports. JIE, do you solved the problem with the generated pdf: "The file is already open or in use by another application"? And what other improves do you maked to the code? Thanks for your tips and code, I´m novice with birt and don´t know how to begin, but your comments are very helpful.
Re: Saving birt output report on server side [message #698008 is a reply to message #696831] Mon, 18 July 2011 15:16 Go to previous messageGo to next message
If you are using event scripting to do this look at the attached example
which does a second render in the beforeRendering event.
Jason
Re: Saving birt output report on server side [message #701934 is a reply to message #698008] Mon, 25 July 2011 18:46 Go to previous messageGo to next message
Thanks, very much for the .rptdesign file and the tips. I will try to implement that in my reports. Best regards!!
Re: Saving birt output report on server side [message #717920 is a reply to message #701934] Mon, 22 August 2011 17:47 Go to previous messageGo to next message
Hello. One more time I need your valuable help. I can already generate my pdf´s, and make the folders if not exists, and personalize the name of the pdf with custom params. But also need to register the name of the resultant document in my DB. I have been looking for tips in the forum, but no entry talk about execute sql in a beforeRender script, or any other event. Do you know any link in the forum where discusses about that?? Sorry for my very bad english. Thanks in advance.
Re: Saving birt output report on server side [message #717940 is a reply to message #717920] Mon, 22 August 2011 18:30 Go to previous messageGo to next message
BIRT does not have any script functions that specifically write back to
a database, but you could always write your own class that inserts into
a db and call it from BIRT event handlers.
Jason
Re: Saving birt output report on server side [message #1060373 is a reply to message #698008] Fri, 24 May 2013 10:50 Go to previous messageGo to next message
Shashank kumar is currently offline Shashank kumarFriend
Hi Jason
First of All thanks for the script in rptdesign file.
I tried it works fine when using in designer. but when running the report using web application ,can see files get created but with no content and been in use by other service.
how to solve this issue?? any help is appreciated..
I am using given script in beforeRender method. and get this exception
Unhandled exception when executing script.
Error.UnhandledScriptError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Unhandled exception when executing script. at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:199) at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:176) at org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleBeforeRender(ReportScriptExecutor.java:123) at org.eclipse.birt.report.engine.api.impl.EngineTask.startRender(EngineTask.java:1376) at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:510) at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:209) at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1444) at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:194) at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238) at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105) at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90) at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47) at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143) at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112) at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397) at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186) at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323) at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32) at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454) at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281) at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265) at javax.servlet.http.HttpServlet.service(HttpServlet.java:616) at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122) at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180) at org.eclipse.equinox.http.servlet.internal.ServletRegistration.handleRequest(ServletRegistration.java:90) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:111) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:59) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:269) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:428) at org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHandler.java:677) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568) at org.mortbay.http.HttpContext.handle(HttpContext.java:1530) at org.mortbay.http.HttpContext.handle(HttpContext.java:1482) at org.mortbay.http.HttpServer.service(HttpServer.java:909) at org.mortbay.http.HttpConnection.service(HttpConnection.java:820) at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:986) at org.mortbay.http.HttpConnection.handle(HttpConnection.java:837) at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:245) at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357) at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)Caused by: org.eclipse.birt.core.exception.CoreException: There are errors evaluating script "mmap = reportContext.getHttpServletRequest().getAttribute("attributeBean").getModuleOptions();rptdoc = reportContext.getHttpServletRequest().getAttribute("attributeBean").getReportDocumentName();importPackage(Packages.org.eclipse.birt.report.engine.api);importPackage(Packages.java.io)var re = reportContext.getReportRunnable().getReportEngine();var mdocument = re.openReportDocument(null,rptdoc, mmap); var options = new PDFRenderOption();baos = new ByteArrayOutputStream(); options.setOutputFormat("pdf");options.setOutputStream(baos);var ntask = re.createRenderTask(mdocument); ntask.setRenderOption(options);ntask.render();ntask.close();mdocument.close();fout = new FileOutputStream("c:/test/myreport1.pdf"); fout.write(baos.toByteArray());fout.flush()fout.close(); ":The choice of Java constructor write matching JavaScript argument types ([B) is ambiguous; candidate constructors are: void write(int) void write(byte[]) (/report/method[@name="beforeRender"]#20). at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:307) at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:335) at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:665) at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleJSInternal(ScriptExecutor.java:60) at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleJS(ScriptExecutor.java:47) at org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleBeforeRender(ReportScriptExecutor.java:115) ... 53 moreCaused by: org.mozilla.javascript.EvaluatorException: The choice of Java constructor write matching JavaScript argument types ([B) is ambiguous; candidate constructors are: void write(int) void write(byte[]) (/report/method[@name="beforeRender"]#20) at org.mozilla.javascript.DefaultErrorReporter.runtimeError(DefaultErrorReporter.java:109) at org.mozilla.javascript.Context.reportRuntimeError(Context.java:1030) at org.mozilla.javascript.Context.reportRuntimeError(Context.java:1086) at org.mozilla.javascript.Context.reportRuntimeError3(Context.java:1064) at org.mozilla.javascript.NativeJavaMethod.findFunction(NativeJavaMethod.java:442) at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:157) at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66) at org.mozilla.javascript.gen.c725._c0(/report/method[@name="beforeRender"]:20) at org.mozilla.javascript.gen.c725.call(/report/method[@name="beforeRender"]) at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:393) at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2834) at org.mozilla.javascript.gen.c725.call(/report/method[@name="beforeRender"]) at org.mozilla.javascript.gen.c725.exec(/report/method[@name="beforeRender"]) at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:302) ... 58 more
Re: Saving birt output report on server side [message #1060483 is a reply to message #698008] Sat, 25 May 2013 07:27 Go to previous messageGo to next message
This is working in birt 3.7.1 but not in 2.3.2 .In 2.3.2 give exception
given below..
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37) at
java.lang.reflect.Method.invoke(Method.java:611) at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112) at
java.lang.reflect.Method.invoke(Method.java:611) at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397) at
org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357) at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534) Caused by: org.eclipse.birt.core.exception.CoreException:
There are errors evaluating script "mmap = reportContext.getHttpServletRequest().getAttribute("attributeBean").getModuleOptions(); rptdoc =
reportContext.getHttpServletRequest().getAttribute("attributeBean").getReportDocumentName(); importPackage(Packages.org.eclipse.birt.report.engine.api); importPackage(Packages.java.io) var
re = reportContext.getReportRunnable().getReportEngine(); var mdocument = re.openReportDocument(null,rptdoc, mmap); var options = new PDFRenderOption(); baos = new
ByteArrayOutputStream(); options.setOutputFormat("xls"); options.setOutputStream(baos); var ntask = re.createRenderTask(mdocument); ntask.setRenderOption(options); ntask.render();
ntask.close(); mdocument.close(); fout = new FileOutputStream("c:/test/testLocale.xls"); fout.write(baos.toByteArray()); fout.flush() fout.close(); ": The choice of Java constructor write matching
org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleBeforeRender(ReportScriptExecutor.java:115) ... 53 more Caused by: org.mozilla.javascript.EvaluatorException: The choice of
org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66) at org.mozilla.javascript.gen.c7._c0(/report/method[@name="beforeRender"]:20) at org.mozilla.javascript.gen.c7.call(/
at org.mozilla.javascript.gen.c7.call(/report/method[@name="beforeRender"]) at org.mozilla.javascript.gen.c7.exec(/report/method[@name="beforeRender"]) at
any idea how to make it work in 2.3.2
[Updated on: Sat, 25 May 2013 07:28]
Report message to a moderator
Re: Saving birt output report on server side [message #1060486 is a reply to message #698008] Sat, 25 May 2013 08:09 Go to previous messageGo to next message
Hi Jason
does it work in birt 2.3.2 or not because when i am trying it getting exception,
and same error as file in use.
It seems some problem with script fout.write(baos.toByteArray());
Plz guide.
[Updated on: Sat, 25 May 2013 13:24]
Re: Saving birt output report on server side [message #1061035 is a reply to message #1060486] Wed, 29 May 2013 15:47 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Are you just using this exact report above in 2.3.2? Let me know. I'll test it out.
Michael
Developer Evangelist, Silanis
Previous Topic:Birt default Excel Emitter
Next Topic:Text Truncating and blank pages in BIRT
Current Time: Thu Apr 26 02:17:43 GMT 2018
Powered by FUDForum. Page generated in 0.02390 seconds
