Tigris Subeclipse plugin fails (silently) on Eclipse [message #649618] |
Wed, 19 January 2011 22:17 |
No real name Messages: 3 Registered: January 2011 |
Junior Member |
I was advised to upgrade to Helios, which I did, but then I needed to install the subeclipse plugin again, which I attempted via the Marketplace.
The subeclipse plugin wasn't completely successful, even though the install restarted eclipse and didn't report any errors (at least not in any dialog).
Previously Subeclipse-enabled projects no longer have the appropriate Team context menus. The only indication the subeclipse plugin installed somewhat is that I can select the perspective, but it appears to be corrupt. SVN doesn't even show up in Team preferences.
Anyone else have this issue? And perhaps come across a workaround?
(I was able to install and use subeclipse on Galileo just fine.)
Installing using the explicit update site did not effect different results.
[Updated on: Wed, 19 January 2011 22:27] Report message to a moderator
FUDForum. Page generated in 0.03463 seconds
