Home » Modeling » EMF » EMF-GWT: a dedicated forum?
EMF-GWT: a dedicated forum? [message #649236] Tue, 18 January 2011 10:27 Go to next message
Giovanni De Sossi is currently offline Giovanni De SossiFriend
Hi all,
I'm a fan of integration between EMF and GWT, as I read in Ken Hussey blog and in Helios New & Noteworthy .
The question is: there is a dedicated forum for this exciting new technology, or are you planning to?
Giovanni.
Re: EMF-GWT: a dedicated forum? [message #649292 is a reply to message #649236] Tue, 18 January 2011 16:02 Go to previous messageGo to next message
Giovanni,
We were just planning to use this forum. Many of the issues that would
come up would be common ones. Mentioning GWT in the title or using [GWT]
as a prefix should do the trick for things specifically about the GWT
version.
Giovanni wrote:
> Hi all,
> http://kenn-hussey.blogspot.com/2010/05/on-where-were-using- emf.htm
> and in Helios
> http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Suppor t_for_Google_Web_Toolkit_.28GWT.29
> Giovanni.
Re: EMF-GWT: a dedicated forum? [message #649511 is a reply to message #649236] Wed, 19 January 2011 14:33 Go to previous messageGo to next message
saurav sarkar is currently offline saurav sarkarFriend
Good that i found this post.
I tried to check the EMF for GWT functionality.
I checked the wiki link, but does this feature has an update site?.
cheers,
Saurav
Re: EMF-GWT: a dedicated forum? [message #649520 is a reply to message #649511] Wed, 19 January 2011 14:45 Go to previous messageGo to next message
Hi Saurav,
did you checked this wiki from Ed Merks? In there you can find useful info about update site and software configuration.
Giovanni.
Re: EMF-GWT: a dedicated forum? [message #649526 is a reply to message #649236] Wed, 19 January 2011 15:04 Go to previous message
Ooops i missed that one.
Thanks Giovanni
cheers,
Saurav
Previous Topic:[CDO] Query instances of abstract types
Next Topic:Problem save xml resource
Current Time: Fri May 25 22:54:49 GMT 2018
Powered by FUDForum. Page generated in 0.02066 seconds
