Home » Newcomers » Newcomers » "Path Entry Markers?"(Looking for pointers to help get past a likely user problem.)
"Path Entry Markers?" [message #649178] Tue, 18 January 2011 03:04 Go to next message
Jeffrey Gossett is currently offline Jeffrey GossettFriend
I have a C++ project that compiles and links ok, but Eclipse seems to hang up at the end of the build. It seems to be trying forever to create "Path Entry Markers."
Any ideas of what may be wrong would be greatly appreciated.
Re: "Path Entry Markers?" [message #649191 is a reply to message #649178] Tue, 18 January 2011 05:41 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Sticky post at top of this forum? You'll get more and better help with
C/C++ issues in the Eclipse CDT forum than this one.
Re: "Path Entry Markers?" [message #661065 is a reply to message #649178] Wed, 23 March 2011 00:04 Go to previous messageGo to next message
Dave Milici is currently offline Dave MiliciFriend
I ran into this just recently after successfully using Eclipse Helios CDT for several months. However Eclipse grinds to a crawl when it got into this state, so I'm wondering why there aren't more posts about this major annoyance.
The workaround I found was to turn C++ Indexing off and then exiting Eclipse. The Path Entry Marker job had to be cancelled, and it still took a few minutes to get to saving workbench data. Only after relaunching Eclipse were things back to normal.
If somebody knows the correct remedy, they will be bigtime heroes.
Re: "Path Entry Markers?" [message #661780 is a reply to message #661065] Sun, 27 March 2011 19:55 Go to previous message
BSchmitt is currently offline BSchmittFriend
can confirm the idential problem (HELIOS build, CDT). Your suggested workaround (turn off INDEXER and close Eclipse, restart Eclipse and turn INDEXER on again) was successful. Thanks for the hint.
Previous Topic:Update Plugin Issue
Next Topic:Trying to run eclipse/java for the first time, exit code 13
Current Time: Fri May 25 09:21:34 GMT 2018
Powered by FUDForum. Page generated in 0.03049 seconds
