Home » Eclipse Projects » Rich Client Platform (RCP) » add combobox to toolbar and change drop-down list programmatically(add combobox to toolbar and change drop-down list programmatically)
add combobox to toolbar and change drop-down list programmatically [message #648194] Tue, 11 January 2011 18:08 Go to next message
fran81 Missing name is currently offline fran81 Missing nameFriend
I am trying to add a combobox to a toolbar in an eclipse rcp app. but I'd also like to have the content of the drop-down list changing programmatically (i.e. depending on other events). Right now this combobox works, but it's on a view instead of a toolbar.
Is there a way to achieve this by setting the plugin.xml (it looks like the content of the dropdown needs to be set this way at the beginning, and cannot be changed programmatically)?
Is there another way to do that?
Francesca
Re: add combobox to toolbar and change drop-down list programmatically [message #649333 is a reply to message #648194] Tue, 18 January 2011 19:02 Go to previous messageGo to next message
I found out how to do this, so I thought I may as well share.
To show a combobox (or other buttons) on the toolbar one can create a class for example
public class DoThis extends Action implements IWorkbenchAction {
public DoThis() {
this class should implements the method
public Menu getMenu(Control parent) {
to actually show a combobox and the menu should be populated by menuitems.
After that one needs to add this action to the toolbar. To do that I have written this code in the class that display the view that contains the toolbar
DoThis myaction = new DoThis();
getViewSite().getActionBArs().getToolBarManager().add(myacti on);
Re: add combobox to toolbar and change drop-down list programmatically [message #649335 is a reply to message #648194] Tue, 18 January 2011 19:21 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can place a <control/> in a toolbar using the org.eclipse.ui.menus
contribution. You can also create a dropdown toolitem and fill in the
dropdown menu dynamically also use org.eclipse.ui.menus and a <dynamic/>
element.
See some of the examples in my .sig links
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Scrollbar For TextBox
Next Topic:eclipse rcp + spring + eclipselink
Current Time: Mon May 21 07:17:06 GMT 2018
Powered by FUDForum. Page generated in 0.02162 seconds
