Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Progress Bar Popup(Unsure of how to make one appear)
Progress Bar Popup [message #648170] Tue, 11 January 2011 15:24 Go to next message
ouri.maler is currently offline ouri.malerFriend
I'm currently designing a GUI, and I've been wanting to integrate a progress bar into it, but I'm uncertain of how to proceed.
I've played with the ProgressBar Class, and I've managed to make one appear in one of the GUI's tabs. However, what I want to do is have the progress bar pop up in its own window whenever the relevant action is launched. Several hours of googling later, I'm still not sure how to do that...Are there classes for opening additional windows?
Re: Progress Bar Popup [message #648304 is a reply to message #648170] Wed, 12 January 2011 10:38 Go to previous messageGo to next message
Lakshmi ShanmugamFriend
To open a new window you need to create a new Shell and open it (Shell.open()). You can create your progress bar within this shell.
These example snippets will be useful --
The first 4 snippets under Shell show different ways to opening a dialog --> http://eclipse.org/swt/snippets/#shell
Snippets to update progressbar --> http://eclipse.org/swt/snippets/#progressbar
HTH,
Lakshmi
Lakshmi P Shanmugam
Re: Progress Bar Popup [message #648811 is a reply to message #648304] Fri, 14 January 2011 15:48 Go to previous message
Lakshmi Shanmugam wrote on Wed, 12 January 2011 05:38
HTH,
Lakshmi
Thanks a lot!
...Opening a new Shell had actually been one of the first solutions I'd tried, but I'd neglected to call open(). I wasn't certain why it wasn't working, and figured maybe only one Shell could be called at a given time... Embarrassed
Previous Topic:Render problems for custom context menu in OpenGL / SWT
Next Topic:Drawing shapes
Current Time: Wed Apr 25 07:18:09 GMT 2018
Powered by FUDForum. Page generated in 0.01566 seconds
