Home » Newcomers » Newcomers » Eclipse exiting when closing a html(Eclipse is exiting when try to close an xhtml file.)
Eclipse exiting when closing a html [message #646694] Thu, 30 December 2010 07:11 Go to next message
chamila piyasena is currently offline chamila piyasenaFriend
In my eclipse when I try to close an xhtml file it always exits giving the following exception.
JVM terminated. Exit code=1
/usr/bin/java
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx2048m
-Djava.library.path=/usr/lib/jni
-jar /opt/eclipse-helios-3.6.1//plugins/org.eclipse.equinox.launc her_1.1.0.v20100507.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /opt/eclipse-helios-3.6.1/eclipse
-name Eclipse
--launcher.library /opt/eclipse-helios-3.6.1//plugins/org.eclipse.equinox.launc her.gtk.linux.x86_64_1.1.1.R36x_v20100810/eclipse_1309.so
-startup /opt/eclipse-helios-3.6.1//plugins/org.eclipse.equinox.launc her_1.1.0.v20100507.jar
-exitdata b48016
-product org.eclipse.epp.package.jee.product
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx2048m
I'm using ubuntu 10.10
Any ideas please?
Re: Eclipse exiting when closing a html [message #646983 is a reply to message #646694] Mon, 03 January 2011 19:26 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
On 12/30/10 2:12 AM, chamila piyasena wrote:
> /usr/bin/java
What version of Java does /usr/bin/java point to? If it's anything other
than the Sun/Oracle JDK (for example, gcj), then you need to install the
Sun/Oracle JDK and point Eclipse to it, as described here:
http://wiki.eclipse.org/Eclipse.ini
> -Xms40m
> -Xmx2048m
> -os linux
> -ws gtk
> -arch x86_64
> -showsplash
> -name Eclipse
> --launcher.library
> -exitdata b48016
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx2048m
> Any ideas please?
Previous Topic:Clean Up...
Next Topic:Permgen space in eclipse galileo
Current Time: Thu May 24 06:38:17 GMT 2018
Powered by FUDForum. Page generated in 0.03134 seconds
