Home » Newcomers » Newcomers » Import svn netbeans project to eclipse
Import svn netbeans project to eclipse [message #646403] Thu, 23 December 2010 18:35 Go to next message
sexus6  is currently offline sexus6 Friend
I configure eclipse to checkout a netbeans project, hosted at sourceforge. I select NEW -> SVN -> Project from SVN.
All files was downloaded in a eclipse project. The filesystem's project like this:
/project-svn
/project-svn/lib => some jar files needed to add at build path
/project-svn/nbproject => some configuration files from netbeans, I guess.
/project-svn/Resources => some text files
/project-svn/src => the java source
/project-svn/test => empty
build.xml
manifest.mf
If I try to ant the build.xml at the root directory, shows me several error, because the jar files at lib dir is not configured in build path.
Then I try to configure build path, whith right click in the project and Properties, there is not any option to build path.
There are not option in that menu that show java project options. How can I transform this for eclipse?
Re: Import svn netbeans project to eclipse [message #646406 is a reply to message #646403] Thu, 23 December 2010 18:51 Go to previous messageGo to next message
Philip Langer is currently offline Philip LangerFriend
Member
the Java build path should be configurable in the properties window of
your project. Please consult:
http://help.eclipse.org/helios/topic/org.eclipse.jdt.doc.use r/reference/ref-properties-build-path.htm
Hope that helps!
Philip
> like this:
> /project-svn
> build.xml
> manifest.mf
> Thanks
Re: Import svn netbeans project to eclipse [message #646407 is a reply to message #646403] Thu, 23 December 2010 19:02 Go to previous messageGo to next message
Member
Sorry, forgot to mention the ant specific point:
Eclipse invokes your ant file as if you would invoke it from your shell.
Therefore, Eclipse won't "inject" your build path settings to the ant
file execution.
Consequently, the class path to use in the javac call in your ant-file
has to be set manually. Maybe the path in your ant file is wrong/missing...
Philip
> like this:
> /project-svn
> build.xml
> manifest.mf
> Thanks
Re: Import svn netbeans project to eclipse [message #646410 is a reply to message #646403] Thu, 23 December 2010 19:38 Go to previous message
David Wegener is currently offline David WegenerFriend
On Thu, 2010-12-23 at 13:35 -0500, sexus6 wrote:
> I configure eclipse to checkout a netbeans project, hosted at sourceforge.. I select NEW -> SVN -> Project from SVN.
> /project-svn
> build.xml
> manifest.mf
> Thanks
A project has to be a Java project to configure the build path. Since
the project wasn't created in Eclipse, it doesn't have the configuration
files necessary to define it as a Java project. I believe that the SVN
plugin has the option to Checkout as.... This allows you to check the
project out as a Java project. You can then configure the build path
for the project.
Previous Topic:Tutorials
Next Topic:Difficulty to run java file
Current Time: Sat May 26 12:07:24 GMT 2018
Powered by FUDForum. Page generated in 0.03749 seconds
