Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » building gnu target on linux 64 bit machines
building gnu target on linux 64 bit machines [message #646261] Wed, 22 December 2010 23:02 Go to next message
Patrick Geremia is currently offline Patrick GeremiaFriend
Member
we are building some code for the gnu target on linux 64 machines
(ubuntu distro).
We almost always compile with the -m32 gcc option as our code is seldom
64-bit ready.
The problem is that by default XDCtools adds /ust/lib as library search
path which on a 64 bit machine points to 64 bit libraries and hence the
following messages
# lnk86U ti_wbi_demo_runtime_debug_seq_86U.x86U ...
/usr///bin/gcc -m32 -lm -o ti_wbi_demo_runtime_debug_seq_86U.x86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/freq_shift _512_le.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_rx_em.o 86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_fft_iff t.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/freq_shift _1024_le.o86U package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/tbSize_tab le.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/memmgr.o86 U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/cppi_devic e.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/freq_shift _2048_le.o86U package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_rx_proc ess.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_rx.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/qmss_devic e.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_rx_soft slicer.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U_x86U.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/pusch_MCS_ table.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/osal.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U/src/ul_rx_main _par_em.o86U
package/cfg/ti_wbi_demo_runtime_debug_seq_86U_x86U.xdl -lstdc++
-L/usr//lib
/usr/bin/ld: skipping incompatible /usr//lib/libm.so when searching for -lm
/usr/bin/ld: skipping incompatible /usr//lib/libm.a when searching for -lm
/usr/bin/ld: warning:
package/cfg/ti_wbi_demo_runtime_debug_seq_86U_x86U.xdl contains output
sections; did you forget -T?
/usr/bin/ld: skipping incompatible /usr//lib/libc.so when searching for -lc
/usr/bin/ld: skipping incompatible /usr//lib/libc.a when searching for -lc
How can I control this? Ideally I would need a mean to detect whether
the host I use for compilation is 32 or 64 bit and then select the
appropriate search path?
Looking at the XDC packages, the property is a module wide config and I
am not sure how to change it?
Linux86.lnkOpts// User configurable linker options = ITarget2.Options {
prefix: "",
suffix: "-Wl,-Map=$(XDCCFGDIR)/$@.map -lstdc++ -L$(rootDir)/lib"
Re: building gnu target on linux 64 bit machines [message #646390 is a reply to message #646261] Thu, 23 December 2010 16:11 Go to previous message
Dave Russo is currently offline Dave RussoFriend
> (ubuntu distro).
> 64-bit ready.
> following messages
[snip]
Right. I'm not sure how to detect this reliably, but if there is a
command you can run that gives you the information you can use
xdc.exec() to run the command from your config.bld script. See
http://rtsc.eclipse.org/docs-tip/XDCscript_-_xdc.exec.
Since config.bld is re-run for _every_ package it might be better to set
an environment variable and use java.lang.System.getenv().
The config options of a target can be set in your config.bld file. In
this case, you might set them as follows:
Linux86 = xdc.module("gnu.targets.Linux86");
Linux86.lnkOpts.suffix = "-Wl,-Map=$(XDCCFGDIR)/$@.map -lstdc++";
Previous Topic:linking with DSP/BIOS 5
Next Topic:package not building when XDCOPTIONS not set to -v
Current Time: Thu Apr 26 08:07:14 GMT 2018
Powered by FUDForum. Page generated in 0.01986 seconds
