Home » Archived » Test and Performance Tools Platform (TPTP) » " The launch requires at least one data collector to be selected"
" The launch requires at least one data collector to be selected" [message #646130] Wed, 22 December 2010 09:27
No real name is currently offline No real nameFriend
I'm trying to profile my webapp in Tomcat using TPTP, and I cannot add an agent. Instead, I get this " The launch requires at least one data collector to be selected" message.
I have installed TPTP via the software update, and I configured the Agent Controller via SetConfig.bat
I have checked that the JVM used in both Eclipse and serviceconfig.xml is exactly the same (JRE 1.6).
I added two hosts : localhost each time, with ports 10002 and 10006 (since I noticed SampleClient connects on port 10006).
I set the AC's log level to DEBUG : I can see that when I tell Eclipse to refresh the available agents list, it is connecting to the ACServer. Here is the log in ACServer :
<CommonBaseEvent creationTime="2010-12-22T09:11:44.019000Z" globalInstanceId="A0561340CDD94FF5BC6B2534728BB3A6" msg="Validated message of 36 bytes" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\CCTLServer.c, line 295" instanceId="1004" location="S08090201" locationType="IPV4" processId="3604" subComponent="Client Compatibility TL" threadId="2812" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.019000Z" globalInstanceId="AAC405F62E774534A76726D7E8464A9C" msg="Processing message of length 36 bytes." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\CCTLServer.c, line 309" instanceId="1004" location="S08090201" locationType="IPV4" processId="3604" subComponent="Client Compatibility TL" threadId="2812" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.019000Z" globalInstanceId="AAED8711368B45AE9854D28D5F77CD7E" msg="Processing RA_QUERY_PROCESS_LIST" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\CCTLServer.c, line 129" instanceId="1004" location="S08090201" locationType="IPV4" processId="3604" subComponent="Client Compatibility TL" threadId="2812" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.019000Z" globalInstanceId="A9C0B4D3BA6A4F1EBD5B33B572681FB1" msg="Sent 40 bytes to client" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\RACClientSupport.c, line 368" instanceId="1004" location="S08090201" locationType="IPV4" processId="3604" subComponent="Client Compatibility TL" threadId="2812" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.035000Z" globalInstanceId="A410476898EE4E96879ECA60B88F3F6E" msg="ConnectionManger - successfully added connectionID 105 for transportID 1004" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="S08090201" locationType="IPV4" processId="3604" subComponent="Connection Manager" threadId="1632" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.035000Z" globalInstanceId="AC854F97C26343578CCAF34DE2846A42" msg="Sent 40 bytes to client" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\RACClientSupport.c, line 368" instanceId="1004" location="S08090201" locationType="IPV4" processId="3604" subComponent="Client Compatibility TL" threadId="1632" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.035000Z" globalInstanceId="A98206B4086D458396F5E89620C2692E" msg="ConnectionManger - successfully added connectionID 106 for transportID 1004" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.035000Z" globalInstanceId="A2BC98725128438B932D687B9026B878" msg="Sent 40 bytes to client" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A39B411F46FD4F6FB358F63851C9B392" msg="Socket processClientRequest: Read 12 bytes." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 603" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A99351502B7E4D80840B914F953E696B" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 489" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AEFC4398F4424635836EAA97B7285C8F" msg="Socket: Read at least one complete message, process it." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 515" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AA1C4CA8AC0B46EFB4B59117448E1E73" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 531" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A9569343946B47D0BF30A2229C064FE6" msg="Socket: handle CONNECT request (Control channel)." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 200" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A28250D7B64B49169F74FB7281132466" msg="ConnectionManger - successfully added connectionID 107 for transportID 1000" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="S08090201" locationType="IPV4" processId="3604" subComponent="Connection Manager" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A09F42F8BA7A47CC878EF9E71C1339D0" msg="Socket handleCONNECT: using Connection ID: 107" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 218" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AE1962F2E432454BBD9B1E6EA42ABEB8" msg="Socket processClientRequest: Read 129 bytes." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AA14A66C02DD426E9C6C1C16A2F0DC7E" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AF143F23354442BC93D348F1072250B8" msg="Socket: Read at least one complete message, process it." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="AA501DC71340421FAF357EA77615B44C" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A43BF73BA64147A8AE83E4A7CEA72EB3" msg="Socket processTheMessageHeader: Stripped header from non-TL message." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 383" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A61C5EE3776A470A9B98F7181861CA0A" msg="queryRunningAgents called" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentManager.c, line 1661" instanceId="1" location="S08090201" locationType="IPV4" processId="3604" subComponent="Agent Manager" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="ABD8DBAAB1DA4762990147C231E203B9" msg="sendMessage (socket) to this connection id(107)" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 1068" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.050000Z" globalInstanceId="A717D59C791D407592297B8520FA90A3" msg="Socket: Sent 228 bytes on connection ID 107" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c, line 1126" instanceId="1000" location="S08090201" locationType="IPV4" processId="3604" subComponent="Socket TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AB0ADFA39052475BA57D3F7893469905" msg="Socket processClientRequest: Read 164 bytes." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A357F8280BF04C1CA1418CD12E01BA8B" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A629441F55A847E7864D71B12203C942" msg="Socket: Read at least one complete message, process it." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AEF27765F69C4B57828819471BFA0563" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A6A4199D1F3C452DAAF2B554F4495066" msg="Socket processTheMessageHeader: Stripped header from non-TL message." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AA37CD95FE8046C5AF5921755C999563" msg="getAgentByToken( 1073741925 ) called" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentManager.c, line 1007" instanceId="1" location="S08090201" locationType="IPV4" processId="3604" subComponent="Agent Manager" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AA5C1E6C538D47FBB02ED151AAC5B7DE" msg="getAgentByID( 101 ) called" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentManager.c, line 895" instanceId="1" location="S08090201" locationType="IPV4" processId="3604" subComponent="Agent Manager" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="ADBCB02E0C8B455E88510E3E128A0CC1" msg="sendMessage (named pipe) to this connection id(101)." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 1236" instanceId="1002" location="S08090201" locationType="IPV4" processId="3604" subComponent="Named Pipe TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="ABFD69B13F494CC5BA980D60176351B7" msg="NamedPipe: Sent 156 bytes on connection ID 101" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 222" instanceId="1002" location="S08090201" locationType="IPV4" processId="3604" subComponent="Named Pipe TL" threadId="3304" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A3A7DEB80E9A40578DF6979D461F8198" msg="sendMessage (socket) to this connection id(107)" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A072922AAE90470D9F868E057A3FDD71" msg="Received(911 bytes)." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 854" instanceId="1001" location="S08090201" locationType="IPV4" processId="3604" subComponent="Named Pipe TL" threadId="3428" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A9A6A7F1A9CB492D9F38563A565B6378" msg="Validated message of 911 bytes" severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 770" instanceId="1001" location="S08090201" locationType="IPV4" processId="3604" subComponent="Named Pipe TL" threadId="3428" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A6A5D43BDC9145E49A55FD81CCFB554F" msg="Agent(101): processRecdMsgs()." severity="5" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp, line 853" instanceId="101" location="S08090201" locationType="IPV4" processId="3844" subComponent="ProcessController" threadId="1636"/>
<situationType reasoningScope="INTERNAL" reportCategory="LOG" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AEDB4D4DFB914B6BA21505F2C8B330AA" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 1105" instanceId="1001" location="S08090201" locationType="IPV4" processId="3604" subComponent="Named Pipe TL" threadId="3428" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AEA4F924EEA941DEA6DC65A9CDE700C4" msg="Socket: Sent 168 bytes on connection ID 107" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AD2371E639A9437BBD9C37616F8DD4FB" msg="sendMessage (named pipe) to this connection id(101)." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AA0D69CA4367450483D1C656B756C71F" msg="NamedPipe: Sent 167 bytes on connection ID 101" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="AC29E7C2C6844F3AAFE476A9E6520636" msg="Received(933 bytes)." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A3FF3B2BAE704A20B97C92F8097E1CF5" msg="Validated message of 933 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A3B704D94C1B4C99AE47B74E7AE62805" msg="Agent 'ProcessController' handling xml cmd" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp, line 947" instanceId="101" location="S08090201" locationType="IPV4" processId="3844" subComponent="ProcessController" threadId="1636"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A003648FB8924E0A9609C3139FA8E89F" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A444B39E3DDA458B96D61DB879EC2C3D" msg="Received(1164 bytes)." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="ADC9B511E86B4D20A47D547DD3DFDA00" msg="Validated message of 1164 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A599322BE78B44CB8827526A9916F1E8" msg="Agent 'ProcessController' parsed xml cmd &lt;Cmd src=&quot;1&quot; dest=&quot;101&quot; ctxt=&quot;-1&quot;>&lt;notifyReference iid=&quot;org.eclipse.tptp.Agent&quot;>&lt;clientID >107&lt;/clientID>&lt;flags>0&lt;/flags>&lt;/notifyReference >&lt;/Cmd>" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp, line 953" instanceId="101" location="S08090201" locationType="IPV4" processId="3844" subComponent="ProcessController" threadId="1636"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A083E6DCAB3C4EEAB8AE4C79246A9110" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A6C9447BBA1F442DB3F699A6B7A173FA" msg="Received(958 bytes)." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A10AC3C33E164202AC9D866D900C3795" msg="Validated message of 958 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.160000Z" globalInstanceId="A88B2382174144CCB31279C22DEF2604" msg="PC processCommand: BaseAgent handled cmd:notifyReference" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\tptpProcessController\tptpProcessController. cpp, line 1901" instanceId="101" location="S08090201" locationType="IPV4" processId="3844" subComponent="ProcessController" threadId="1636"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A667B5250152420EABC9BE02FB5F59DB" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A3550A319BE44651814D3565BF4F6B33" msg="Received(936 bytes)." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A9A63B7538FE48388AEB142AC61AA9ED" msg="Validated message of 936 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A5A8FBE4E05B4FDFBCBA5DF7162D0105" msg="Agent(101): Bytes in msg left to be processed: 0 bytes." severity="5" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp, line 887" instanceId="101" location="S08090201" locationType="IPV4" processId="3844" subComponent="ProcessController" threadId="1636"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="A86DDF4987D94E5BB7AEF604BFBC2A3F" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2010-12-22T09:11:44.176000Z" globalInstanceId="AB50E0346609476EB7DA858A8481C90C" msg="Received(911 bytes)." severity="5" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 854" instanceId="1001" location="S08090201" locationType="IPV4" processId="3604&q
Previous Topic:Over 200 deadlocks - correct?!
Next Topic:Run all unittests of current workspace from within Eclipse?
Current Time: Sun Jan 21 06:50:26 GMT 2018
Powered by FUDForum. Page generated in 0.01515 seconds
