Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Could not start the server with a different port and group(Could not start with a different port. The server by default starts with 3232 and server (group).)
Could not start the server with a different port and group [message #645210] Wed, 15 December 2010 23:15 Go to next message
Aykut Yararbas is currently offline Aykut YararbasFriend
I am using eclipse helios.Installed the latest ECF plugin.
I could start the server using eclipse.exe -console -application org.eclipse.ecf.server.generic.Server.
I am following the instructions in http://wiki.eclipse.org/ECF_Servers page.
I tried to start to server with a different port ( I used the one in the page eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000 )
Is there another way to start the server with a different port and group , with eclipse.exe -application command ?
Thanks and regards,
Aykut Yararbas
aykutyararbas@yahoo.com
I got an error and log file created ;
_-------------------------------------_ LOG_ under /eclipse/configurations/1233.....log
!SESSION 2010-12-15 15:09:40.929 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product -console -application org.eclipse.ecf.provider.AppGenericServer 3285 mygroup ecf.eclipse.org 20000
!ENTRY org.eclipse.osgi 4 0 2010-12-15 15:09:42.390
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ecf.provider.AppGenericServer" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFi leEditor, org.eclipse.ecf.example.clients.chatroomrobot, org.eclipse.ecf.example.clients.chatsorobot, org.eclipse.ecf.example.clients.chatrobot, org.eclipse.ecf.examples.eventadmin.app.EventAdminManager, org.eclipse.ecf.examples.eventadmin.app.EventAdminClient, org.eclipse.ecf.examples.remoteservices.hello.consumer.Hello Consumer, org.eclipse.ecf.examples.remoteservices.hello.ds.consumer.He lloConsumerDS, org.eclipse.ecf.examples.remoteservices.hello.ds.host.HelloH ostDS, org.eclipse.ecf.examples.remoteservices.hello.host.HelloHost , org.eclipse.ecf.examples.updatesite.server.updateSiteServer, org.eclipse.ecf.presence.bot.chatRoomRobot, org.eclipse.ecf.presence.bot.imRobot, org.eclipse.ecf.server.generic.Server, org.eclipse.ecf.server.generic.Client, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.generator.EclipseGenerator, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher , org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.metadata.repository.mirrorApplication , org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
[Updated on: Wed, 15 December 2010 23:17]
Report message to a moderator
Re: Could not start the server with a different port and group [message #645325 is a reply to message #645210] Thu, 16 December 2010 16:08 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus KuppeFriend
> lloConsumerDS,
> tarter.java:369)
> tarter.java:179)
Hi Aykut,
I assume you use an ECF version newer than 2.0. Thus the application cmd
line parameter is named "org.eclipse.ecf.server.generic.Server" instead
of "org.eclipse.ecf.provider.AppGenericServer".
HTH
Markus
Re: Could not start the server with a different port and group [message #647198 is a reply to message #645325] Wed, 05 January 2011 00:16 Go to previous messageGo to next message
Hi Markus,
Thanks a lot for your comment.
I tried ;
eclipse.exe -console -application org.eclipse.ecf.server.generic.Server 3285 mygroup
And once again 3282 ;
osgi> No support for IPv6 in jSLP yet (see https://bugs.eclipse.org/328074), ski
pping interface...
WARNING: Port 9278 already in use. This instance of R-OSGi is running on port 9279
ZooDiscovery> Discovery Service Activated. Jan 4, 2011 4:11:59 PM.
Generic server started with id=ecftcp://localhost:3282/server
Thanks and regards,
Aykut Yararbas
[Updated on: Wed, 05 January 2011 00:48]
Re: Could not start the server with a different port and group [message #647230 is a reply to message #647198] Wed, 05 January 2011 08:30 Go to previous messageGo to next message
On 01/05/2011 01:16 AM, Aykut Yararbas wrote:
> Hi Mark,
> I tried ;
> org.eclipse.ecf.server.generic.Server 3285 mygroup ecf.eclipse.org 20000
> pping interface...
> port 9279
> Thanks and regards,
> Aykut Yararbas
Hi Aykut,
I assume you want to change the ECF generic provider port from 3282 to
something different. This can be done by setting the system property
"org.eclipse.ecf.provider.generic.port" to the new value.
Markus
Re: Could not start the server with a different port and group [message #647345 is a reply to message #647230] Wed, 05 January 2011 17:36 Go to previous messageGo to next message
Hi Markus,
It works Smile
c:\eclipse-jee-helios-win32-x86_64\eclipse\plugins>java -Dorg.eclipse.ecf.provider.generic.port=3333 -jar org.eclipse.equinox.launcher_1.1.0.v20100507.jar -cons
osgi> No support for IPv6 in jSLP yet (see https://bugs.eclipse.org/328074), skipping interface...
ZooDiscovery> Discovery Service Activated. Jan 5, 2011 9:34:10 AM.
Generic server started with id=ecftcp://localhost:3333/server
How can I set the group ?
Aykut Yararbas
Re: Could not start the server with a different port and group [message #647350 is a reply to message #647345] Wed, 05 January 2011 18:15 Go to previous messageGo to next message
Hi Markus ,
Here I found the parameters from your comment to a bug.
-Dorg.eclipse.ecf.provider.generic.name="/mygroup"
Be careful to start the group name with '/'.
c:\eclipse-jee-helios-win32-x86_64\eclipse\plugins>java -Dorg.eclipse.ecf.provider.generic.port=3333 -Dorg.eclipse.ecf.provider.generic.name="/mygroup" -jar or
g.eclipse.equinox.launcher_1.1.0.v20100507.jar -console -application org.eclipse.ecf.server.generic.Server
ZooDiscovery> Discovery Service Activated. Jan 5, 2011 10:12:33 AM.
Generic server started with id=ecftcp://localhost:3333/mygroup
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=326841
Parameters are ;
org.eclipse.ecf.provider.generic.host ("localhost")
org.eclipse.ecf.provider.generic.name ("/server")
org.eclipse.ecf.provider.generic.scheme ("ecftcp")
Int:
org.eclipse.ecf.provider.generic.port (3282)
org.eclipse.ecf.provider.generic.keepalive (30000)
Comment 1Markus Alexander Kuppe 2010-10-02 09:06:24 EDT
Additionally "org.eclipse.ecf.provider.generic.host.useHostName=true"
overwrites "org.eclipse.ecf.provider.generic.host" with
InetAddress.getLocalHost().getCanonicalHostname() iff set
Re: Could not start the server with a different port and group [message #647354 is a reply to message #647345] Wed, 05 January 2011 18:04 Go to previous messageGo to next message
On 01/05/2011 06:36 PM, Aykut Yararbas wrote:
> Hi Markus,
> It works :)
> port 9279
> Aykut Yararbas
What group?
Markus
Re: Could not start the server with a different port and group [message #647365 is a reply to message #647354] Wed, 05 January 2011 19:13 Go to previous message
Hi Markus,
I mentioned org.eclipse.ecf.provider.generic.name ("/server") name attribute as group.
I found the parameter. See my previous comment.
Thanks and kind regards for your help.
It really resolved my issues.
Aykut Yararbas
Previous Topic:Unable to build ecf tutorials on helios because of dependency
Next Topic:Shared Editor example not working
Current Time: Mon Jan 22 18:37:47 GMT 2018
Powered by FUDForum. Page generated in 0.01857 seconds
