Home » Modeling » BPEL Designer » Error while creating the HelloWorld Tutorial
Error while creating the HelloWorld Tutorial [message #645065] Wed, 15 December 2010 13:34 Go to next message
Bala  is currently offline Bala Friend
I get the following error while working in the BPEL designer.
Grateful for any help to resolve the error.
!SESSION 2010-12-15 17:09:18.046 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data e:\RuntimeWorkspace -dev file:E:/myworkspace/.metadata/.plugins/org.eclipse.pde.core/ BPELconfiguration/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:12:15.578
!MESSAGE Server Ode v1.x Server at localhost failed to start.
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:12:50.093
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:15:34.953
!ENTRY org.eclipse.jface 4 0 2010-12-15 17:19:48.218
!MESSAGE Unhandled event loop exception during blocked modal context.
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizard.perform Finish(TaskWizard.java:221)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.server.ui.internal.actions.LaunchWizardActio n.run(LaunchWizardAction.java:57)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NullPointerException
at org.eclipse.wst.server.ui.internal.wizard.TaskWizardPage.set Message(TaskWizardPage.java:104)
at org.eclipse.jst.server.generic.ui.internal.ServerTypeDefinit ionServerDecorator.validate(ServerTypeDefinitionServerDecora tor.java:41)
at org.eclipse.jst.server.generic.ui.internal.GenericServerWiza rdFragment.enter(GenericServerWizardFragment.java:109)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizard$2$1.run (TaskWizard.java:175)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer. java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 46 more
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:32:32.000
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:32:33.046
!SESSION 2010-12-15 17:40:46.031 -----------------------------------------------
java.version=1.6.0
!ENTRY org.eclipse.core.resources 2 10035 2010-12-15 17:40:50.093
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:29.296
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.ui.dialogs.ContainerSelectionDialog.createDialog Area(ContainerSelectionDialog.java:134)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 760)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage.handleBrowse(ODEDeployWizardPage.java:125)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage.access$1(ODEDeployWizardPage.java:121)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage$2.widgetSelected(ODEDeployWizardPage.java:75)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:254)
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:36.187
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:44.500
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:52.171
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:57.656
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:04.250
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:15.968
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:19.375
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:22.937
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:48.328
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:53.125
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:00.875
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:04.171
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:13.687
!STACK 0
!SESSION Wed Dec 15 17:51:55 PST 2010 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2010-12-15 17:51:55.671
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Re: Error while creating the HelloWorld Tutorial [message #645149 is a reply to message #645065] Wed, 15 December 2010 17:29 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Hi Bala,
Well, from the looks of the stack trace it looks like your VM has run out of PermGen space Wink
Have a look at this page:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
which explains how to allocate more memory to eclipse on start up.
Cheers!
Bob
Re: Error while creating the HelloWorld Tutorial [message #674834 is a reply to message #645149] Sat, 28 May 2011 19:43 Go to previous message
DevByStarlight  is currently offline DevByStarlight Friend
These applications are hungry hippos with significant memory footprints.
Is there any way to determine what's happening during builds (PHP website) that causes the memory to spike from ~100M to 800M for a brief period?
I'm curious so maybe, if it's something which doesn't need to be rebuilt all the time, if I can do something like a "precompiled header" equivalent.
[Updated on: Sat, 28 May 2011 19:54]
Report message to a moderator
Previous Topic:Unable to start BEPL Designer on Helious, fresh install
Next Topic:BPEL process client
Current Time: Tue Feb 20 19:52:51 GMT 2018
Powered by FUDForum. Page generated in 0.01583 seconds
