Home » Newcomers » Newcomers » Eclipse Refactoring (How does Eclipse Re-Analyse source code after Refactoring?)
icon5.gif  Eclipse Refactoring [message #644556] Mon, 13 December 2010 09:35 Go to next message
Dharam  is currently offline Dharam Friend
Hello All!
1. Eclipse uses AST based concept for Refactoring. Refactoring is a "Complete Operation",
- Preceded by set of Preconditions
- Transformation
- Follwed by set of PostConditions
Example:
After applying "Rename Variable" refactoring, Eclipse immediately makes impact analysis & changes the source code
Queries:
Does it also change AST?
If Yes, then it must unparse AST & perform re-analysis to collect results based on new change,
But I am wondering how eclipse does it too fast. For millions of lines of code, static analyis takes lots of time.
Analysis means:
Variable Use
Variable Def
Aliasing Info
Call Graph
gen kill
reaching & liveness
etc...
[Updated on: Mon, 13 December 2010 12:23]
Report message to a moderator
Re: Eclipse Refactoring [message #644635 is a reply to message #644556] Mon, 13 December 2010 14:53 Go to previous messageGo to next message
Dharam,
Comments below.
Dharam wrote:
> Hello All!
> "Complete Operation", - Preceded by set of Preconditions
> - Transformation
> Example:
> makes impact analysis & changes the source code?
> Queries:
Yes.
The analysis is done using the AST.
The incremental compiler is very smart and knows where to focus the
attention.
> Analysis means:
> Variable Use
> Variable Def
> Aliasing Info
> Call Graph gen kill reaching & liveness
> etc...
Re: Eclipse Refactoring [message #644747 is a reply to message #644635] Tue, 14 December 2010 05:06 Go to previous message
Thanks.
I agree with you, changing & unparsing AST is somewht starightforward task. But collecting static analysis results each time after refactoring very expensive,
def use / use def
gen kill
aliasing info for each reference variable
liveness
reaching.
Would you pls eloborate more on this? I would also like to request if you can suggest me eclipse library for static analyis used in refactoring.
Previous Topic:Problem with imports
Next Topic:Search results list
Current Time: Thu Apr 26 06:15:36 GMT 2018
Powered by FUDForum. Page generated in 0.03075 seconds
