Home » Modeling » TMF (Xtext) » model to text and comments
model to text and comments [message #644374] Fri, 10 December 2010 17:49 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
I have a use case where I create a (DSL) model using a model to model
transformation and I would like to also insert a few comments (in
selected places). What would be the approach to take for something like
this?
My DSL does not contain any 'assigned rules' for comments, but the
comments are not hidden from the grammar.
I imagine (a somewhat heavy) approach would be to first serialize to
text without comments, then parse the result to get a node model, and
then perform textual changes.
My other idea is to use a "comment adapter" and pick up any comment text
while serializing. However since comments would not be found the same
way when going in the other direction, I am not so fond of this solution.
Some more detail info about the grammar:
In this grammar there are issues with overlapping terminals so basically
everything that is normally handled with terminals is handled as data
rules (i.e. strings, comments, etc.). This also means that there are no
hidden terminals. Instead, all rules typically ends with an
OptionalWhiteSpace (OWS) rule that is defined to be an optional sequence
of white space and comments.
A rule may look like this:
AdditiveExpression returns Expression:
MultiplicativeExpression ({AdditiveExpression.leftExpr=current}
opName = AdditiveOperator OWS
rightExpr = MultiplicativeExpression)*
This works fine as all rules that consumes a token (that may be followed
by WS/Comments) also ends by consuming OWS. (And the root rule consumes
any leading OWS).
- henrik
Re: model to text and comments [message #644774 is a reply to message #644374] Tue, 14 December 2010 08:32 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Henrik,
I'd usually try to use a custom serializer for any use case that
involves heavy customizing.
The other approaches (adapter + comment associater or unassigned text
serializer) involve heavy customizing and I'm not that sure about the
runtime invariants of these components.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 10.12.10 18:49, schrieb Henrik Lindberg:
> this?
> any leading OWS).
> Regards
> - henrik
Re: model to text and comments [message #645098 is a reply to message #644774] Wed, 15 December 2010 15:11 Go to previous message
I managed to make things work by implementing a value serializer and
then dealing with whitespace by returning null. (Returning "" had the
effect that extra whitespace was generated).
What is the difference between returning null and "" when serializing?
I also modified the HiddenTokenHelper to report my non terminal comments
and whitespace rules as such.
I was then able to serialize and also use formatting.
- henrik
On 12/14/10 9:32 AM, Sebastian Zarnekow wrote:
> Hi Henrik,
> Sebastian
Previous Topic: retrieving crossreferences from external file
Next Topic:Xtext - Formatting - SetIndentation
Current Time: Wed Jan 17 09:39:02 GMT 2018
Powered by FUDForum. Page generated in 0.01517 seconds
