Home » Eclipse Projects » EclipseLink » JPA 2 Query casting throwing exception(JPA Criteria API)
JPA 2 Query casting throwing exception [message #644286] Fri, 10 December 2010 07:09 Go to next message
James Rawlings is currently offline James Rawlings
Follwing the example from http:// wiki.eclipse.org/EclipseLink/Release/2.1.0/JPAQueryEnhanceme nts I am casting the query to a subclass using the criteria API Expression.as(type). When casting the result to a Path as per the the example I get a class cast exception.
Root<Employee> empRoot = cq1.from(getEntityManagerFactory().getMetamodel().entity(Employee.class));
Join<Employee, Project> join = empRoot.join("projects");
Path exp = ((Path)join.as(LargeProject.class)).get("budget");
exception thrown..
ClassCastException: Cannot cast org.hibernate.ejb.criteria.expression.function.CastFunction (id=113) to java.persistence.criteria.Path
Can anybody help? Many thanks.
[Updated on: Fri, 10 December 2010 09:26]
Report message to a moderator
Re: JPA 2 Query casting throwing exception [message #644334 is a reply to message #644286] Fri, 10 December 2010 10:20 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
The error states you are using Hibernate as your JPA provider.
You need to use EclipseLink as the provider to get EclipseLink features. ie
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
in your persistence.xml with the EclipseLink jar on your classpath. see
http://wiki.eclipse.org/EclipseLink/Examples
Chris
Previous Topic:BigDecimal correctly persisted but not correctly loaded
Next Topic:TableGenerator Sequencing options
Current Time: Sat May 18 09:13:57 EDT 2013
Powered by FUDForum. Page generated in 0.03762 seconds
