Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Intermittent Bug: Nonsense compiler errors that disappear after file is touched
[Acceleo] Intermittent Bug: Nonsense compiler errors that disappear after file is touched [message #644203] Thu, 09 December 2010 21:41 Go to next message
Glenview Jeff is currently offline Glenview JeffFriend
Member
I've seen this problem happen about three or four separate times in the past few weeks. It might correlate to updating the meta-model and re-generating the editor.
What happens is that the compiler reports errors. In this case No public template "xyz" found.
If I touch (update the modification time) of the file without changing the code, the error disappears.
Is this a known bug?
Jeff
Re: [Acceleo] Intermittent Bug: Nonsense compiler errors that disappear after file is touched [message #644242 is a reply to message #644203] Fri, 10 December 2010 07:54 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
This is a known bug. Errors cannot be completely trusted unless the file is saved.
Stephane Begaudeau, Obeo
[Updated on: Fri, 10 December 2010 07:55]
Report message to a moderator
Re: [Acceleo] Intermittent Bug: Nonsense compiler errors that disappear after file is touched [message #644309 is a reply to message #644242] Fri, 10 December 2010 13:40 Go to previous message
Member
To clarify, these are mtl file errors that didn't occur during editing the mtl file (the file hadn't been touched for days.)
eff
Previous Topic:[Xpand] Determine the template file on runtime in an EXPAND statement
Next Topic:[JET2] Using abbreviate XPATH form in non java files
Current Time: Wed May 23 12:41:43 GMT 2018
Powered by FUDForum. Page generated in 0.02158 seconds
