Home » Eclipse Projects » JFace » Set Selection on Tree Viewer(We aren't able to select a particular item on a tree viewer)
Set Selection on Tree Viewer [message #644089] Thu, 09 December 2010 07:45 Go to next message
Aravindhan Annamalai is currently offline Aravindhan Annamalai
Member
We display a tree viewer, in which we need to select a particular node by default.
The tree when displayed shows only the root node.
We tried using tree paths by,
we constructed the tree path, using createChildPath and got a successfull tree path and used the below methods...
thisTreeViewer.setExpandedState(prevPath, true); --> wasn't working
thisTreeViewer.setExpandedTreePaths(prevPath); --> wasn't working
thisTreeViewer.reveal(prevPath); ---> wasn't working
we tried
StructuredSelection structuredSelections = new StructuredSelection(selectionArray);
thisTreeViewer.setSelection(structuredSelections, true);
which was also not working in our case..
Is there something we are missing here...
only thisTreeViewer.expandAll() is working...
Aravind
Re: Set Selection on Tree Viewer [message #644104 is a reply to message #644089] Thu, 09 December 2010 09:28 Go to previous messageGo to next message
T. Wilhelm is currently offline T. Wilhelm
did you try:
this.treeViewer.getTree().showItem( myTreeItem );
maybe this works for you. Otherwise it would be nice if you post some snippet
Greetz
Thomas
Re: Set Selection on Tree Viewer [message #644107 is a reply to message #644089] Thu, 09 December 2010 09:33 Go to previous message
Daniel Krügler is currently offline Daniel Krügler
On 2010-12-09 13:45, Aravindhan.A wrote:
> by default.
> we tried
This should work. I assume you did not provide equal items when
constructing the selection object. This can happen, if your objects
types don't override equal/hash correctly. You can make your tree
equality-aware without need to modify your types, if you provide an
IElementComparer to the tree (I think you need to activate useHashLookup
to make that work).
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:how to add a double-click listener on TableViewer column header
Next Topic:Embedding images in a org.eclipse.ui.editors.text.TextEditor
Current Time: Sun May 19 02:44:12 EDT 2013
Powered by FUDForum. Page generated in 0.01426 seconds
