Home » Eclipse Projects » BIRT » PermGen Space Error running BIRT reports
PermGen Space Error running BIRT reports [message #643801] Wed, 08 December 2010 10:39 Go to next message
Iain  is currently offline Iain Friend
Im running into the PermGen space issue when I attempt to run Birt reports from within my application when I am running Tomcat within Eclipse.
My ini file is as follows:
-Xms512m
-Xmx512m
-XX:MaxPermSize=256m
However, Ive tried most ever configuration of heap Xms, Xmx and XX:MaxPermSize.
Eclipse Version: Helios Service Release 1
Build id: 20100917-0705
Birt: 2.6.1
java -version gives:
java version "1.6.0_22"
Java(TM) SE Runtime Environment (build 1.6.0_22-b04)
Java HotSpot(TM) Client VM (build 17.1-b03, mixed mode, sharing)
As soon as I starting running Birt reports I get the following error (or similar):
SEVERE: Error processing request
java.lang.OutOfMemoryError: PermGen space
Re: PermGen Space Error running BIRT reports [message #643906 is a reply to message #643801] Wed, 08 December 2010 16:25 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Is this starting another jvm to run tomcat on? You can add the jvm
setting to the catalina.bat file.
Jason
> -Xms512m
> -Xmx512m
> XX:MaxPermSize.
> Birt: 2.6.1
> similar):
Re: PermGen Space Error running BIRT reports [message #643930 is a reply to message #643906] Wed, 08 December 2010 17:49 Go to previous messageGo to next message
Hi, thanks for getting back to me.
I'm running Tomcat from within Eclipse which, I believe, means that it doesn't use the Catalina.bat file.
I'm starting my server from within Eclipse. Within Eclipse's Tomcat configuration I have the following VM arguments:
-Dcatalina.base=" C:\workspace_svn\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp1 " -Dcatalina.home="C:\tomcat" -Dwtp.deploy=" C:\workspace_svn\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp1\wtpwebapps " -Djava.endorsed.dirs="C:\tomcat\endorsed" -Xmx1024m
The classpath tab the bootstrap entry is set to have the jdk1.6.0_22 for the JRE system library. Do you think it's also possible to reference the jvm in these Java options?
Re: PermGen Space Error running BIRT reports [message #643962 is a reply to message #643930] Wed, 08 December 2010 20:11 Go to previous messageGo to next message
Can you add this to the line
-XX:MaxPermSize=256M
Jason
> -Dcatalina.base="
Re: PermGen Space Error running BIRT reports [message #643966 is a reply to message #643962] Wed, 08 December 2010 20:34 Go to previous message
That seems to have solved it! I've been running Birt reports for the last 10 minutes and no PermGen issues when previously I was getting them almost instantly.
Thanks so much Jason.
Previous Topic:Scripted DataSet classpath question
Next Topic:Unable to access selected values of a ListBox type parameter
Current Time: Sun May 20 23:40:33 GMT 2018
Powered by FUDForum. Page generated in 0.02145 seconds
