Home » Eclipse Projects » Eclipse Platform » Exception while performing file search(Resource out of sync exception while performing file search)
Exception while performing file search [message #643749] Wed, 08 December 2010 07:39 Go to next message
Mahesh Maney is currently offline Mahesh ManeyFriend
With Eclipse Helios, i get this "Resource out of sync" when i perform a file search Sad
The search starts and by the time it reaches the end, the search operation fails and an exception is encountered which reads as " org.eclipse.core.internal.resources.ResourceException: Resource is out of sync with the file system: " Crying or Very Sad
Anybody have faced this problem earlier ? anything that has to be addressed? please help Smile
[Updated on: Wed, 08 December 2010 07:40]
Report message to a moderator
Re: Exception while performing file search [message #643762 is a reply to message #643749] Wed, 08 December 2010 08:14 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Mahesh Maney wrote:
> a file search :( The search starts and by the time it reaches the
It does not fail. It just tells you which files couldn't be read because
they are out of sync.
> of sync with the file system: " :cry:
> addressed?
Don't change your resource outside the workspace or refresh your
workspace if you do so.
Dani
> please help :)
Re: Exception while performing file search [message #643781 is a reply to message #643762] Wed, 08 December 2010 09:26 Go to previous messageGo to next message
Dani,
I'm not changing any of the files or supported files outside the eclipse. it happens very randomly when i try to do a search. however the same behavior does not appear with Galileo eclipse.
Re: Exception while performing file search [message #643848 is a reply to message #643781] Wed, 08 December 2010 13:26 Go to previous messageGo to next message
Mahesh,
Is this perhaps a mounted file system? Sometimes there are OS/clock
problems associated with the timestamps for mounted files. Eclipse
compares the timestamp it saved with the actual timestamp on the file.
If those are different, it assumes the file has changed in some way. So
either something is really changing the file, or something in the OS is
randomly returning a different timestamp.
Mahesh Maney wrote:
> Dani,
Re: Exception while performing file search [message #643898 is a reply to message #643749] Wed, 08 December 2010 16:11 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
On 12/8/10 2:39 AM, Mahesh Maney wrote:
> file search :( The search starts and by the time it reaches the end, the
> addressed? please help :)
Right-click on the project or folder that contains the out-of-sync
file(s) and choose Refresh from the pop-up menu.
Eric
icon14.gif  Re: Exception while performing file search [message #645407 is a reply to message #643848] Fri, 17 December 2010 07:02 Go to previous message
Merks,
you are right. we are using mounted file system and there were time stamp differences. this helped me. thank you again Smile
Previous Topic:Eclipse Closed automatically
Next Topic:Eclipse Plugin - Debugger - Automatically select the top stackframe
Current Time: Tue Apr 24 14:49:20 GMT 2018
Powered by FUDForum. Page generated in 0.01616 seconds
