Home » Eclipse Projects » Rich Client Platform (RCP) » Missing "Plugin Development" preference item
Missing "Plugin Development" preference item [message #643723] Wed, 08 December 2010 01:50 Go to next message
John Lussmyer is currently offline John LussmyerFriend
Member
This is kind of embarrassing, as I know I must be missing something obvious. I've been using Eclipse for Java app development for a long time.
I'm starting to learn about developing an app using RCP.
Reading the FAQ, there is this:
" Now, any plug-in projects in your workspace will build and run against the RCP SDK plug-ins rather than the IDE's.
If you are developing against the same version as the Eclipse SDK, there is new support in since 3.2 M5 that simplifies setting up the Target Platform for RCP development, and makes it easier to incrementally include other plug-ins from the SDK build.
1. Go to Window > Preferences > Plugin-Development > Target Platform."
The only problem is that my installation of Eclipse doesn't HAVE a "Plugin-Development" entry anywhere in the Preferences dialog.
I'm running
Version: Helios Service Release 1
Build id: 20100917-0705
Re: Missing "Plugin Development" preference item [message #643857 is a reply to message #643723] Wed, 08 December 2010 13:33 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> I'm running Version: Helios Service Release 1
You need to go to the Helios Discover site (Help>Install New Software)
and select General Purpose Tools>Eclipse Plug-in Development
Environment. That'll get you PDE.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Missing "Plugin Development" preference item [message #643878 is a reply to message #643857] Wed, 08 December 2010 15:16 Go to previous message
Member
Thanks! I figured it must be something simple like that.
Previous Topic:headless build for RCP application on freebsd
Next Topic:Export wont recognize selected Target
Current Time: Sat Apr 21 17:49:31 GMT 2018
Powered by FUDForum. Page generated in 0.01426 seconds
