Home » Modeling » TMF (Xtext) » knowing the java package of the model generated classes
knowing the java package of the model generated classes [message #643631] Tue, 07 December 2010 16:47 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
in my DSL I have a statement like the following
'grammar' ePackage=[ecore::EPackage|STRING]
with which I load an EPackage.
now, I'd like to know the java package of the corresponding EMF
generated classes (in particular the package of the generated interfaces).
Thus, for instance, if I write in my program
grammar "mypatch/to/my.ecore"
I'd like to know where the EMF classes corresponding to my.ecore are
generated.
Is there a direct way to achieve this? Or should I go through the
corresponding genmodel? if so, could someone point me to some example on
how to do this please?
many thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: knowing the java package of the model generated classes [message #643666 is a reply to message #643631] Tue, 07 December 2010 18:46 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Lorenzo,
you have to find the respective genmodel and inspects its values. The
EPackage itself does not know about the (to be) generated artifacts.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 07.12.10 17:47, schrieb Lorenzo Bettini:
> Hi
> generated.
> Lorenzo
Re: knowing the java package of the model generated classes [message #643686 is a reply to message #643666] Tue, 07 December 2010 20:14 Go to previous messageGo to next message
On 12/07/2010 07:46 PM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Sebastian
thanks
for this purpose it might be enough to look into the same directory
where the EPackage, however, given an EPackage I can't seem to find a
way to get the path of the corresponding ecore... I guess I have to
store that information somewhere else when I load the EPackage, can it be?
cheers
Lorenzo
Re: knowing the java package of the model generated classes [message #643701 is a reply to message #643686] Tue, 07 December 2010 22:15 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
Alternatively, you could reference (through a URI) the GenModel instance (from the GenModel Ecore meta model) which holds a reference (URI) to the EPackage.
Re: knowing the java package of the model generated classes [message #643790 is a reply to message #643701] Wed, 08 December 2010 09:32 Go to previous messageGo to next message
> the EPackage.
you mean: instead of loading the .ecore file, load the .genmodel file,
then from there, through GenModel, get a reference to EPackage?
cheers
Lorenzo
Re: knowing the java package of the model generated classes [message #643806 is a reply to message #643701] Wed, 08 December 2010 10:47 Go to previous messageGo to next message
> the EPackage.
By the way, I managed to get a GenModel instance, but I can't seem to
find the information you talk about from GenModel instance...
Re: knowing the java package of the model generated classes [message #643901 is a reply to message #643806] Wed, 08 December 2010 16:19 Go to previous messageGo to next message
If you open the .genmodel file in an(y) appropriate editor, then you should a 'foreignModel' element as the first child of the root.
Re: knowing the java package of the model generated classes [message #643912 is a reply to message #643806] Wed, 08 December 2010 16:48 Go to previous message
Hi Lorenzo,
have a look at the attributes of the corresponding GenPackage. It should
expose something like base package.
Sebastian
Am 08.12.10 11:47, schrieb Lorenzo Bettini:
>> the EPackage.
Previous Topic:ContentAssist - CodeCompletion with Templates for Function-Parameters
Next Topic:createNode is not called for MySyntaxTransformer.java
Current Time: Sat May 26 23:48:26 GMT 2018
Powered by FUDForum. Page generated in 0.02280 seconds
