Home » Eclipse Projects » P2 » p2 folder and artifacts.xml file
p2 folder and artifacts.xml file [message #643585] Tue, 07 December 2010 14:55 Go to next message
Vasily Lukichev is currently offline Vasily LukichevFriend
Member
Hello All,
Can someone explain me why I have "p2" directory and "artifacts.xml" file created in the place where I run eclipse even if I specify "-configuration" option?
I thought that p2 and artifacts.xml must be located under the path specifed with "-configuration" parameter.
Thanks in advance!
Vasily.
Re: p2 folder and artifacts.xml file [message #643779 is a reply to message #643585] Wed, 08 December 2010 09:24 Go to previous message
Member
Hmm...
Yesterday I thought that I am going mad...
Anyway I found an answer to my question.
May be the information will be useful and someone can save some time...
Example, you start eclipse with
-configuration <some_path>/FolderA/FolderB/FolderC
option.
In that case FolderC will contain Configuration locations contain files which identify and manage the (sub)set of an install to run.(c)
And FolderB will contain "p2" folder and "artifacts.xml" file. I tried to find documentation regarding that but failed.
So, no magic here.
Vasily.
Previous Topic:Missing requirement during Equinox p2 director application usage
Next Topic:Installing with p2 fails silently
Current Time: Tue Jan 23 00:17:23 GMT 2018
Powered by FUDForum. Page generated in 0.01311 seconds
