Home » Eclipse Projects » GEF » GEF binaries for 64 bit eclipse(Need to install Gef binaries on 64 bit eclipse)
GEF binaries for 64 bit eclipse [message #643534] Tue, 07 December 2010 10:02 Go to next message
sridhar gooni is currently offline sridhar gooniFriend
I am using eclipse-SDK-3.6.1-win32-x86_64 in windows-2k8 64 bit machine. In the eclipse I need to install gef binaries. In the downloads section i could not find any specific downloads for 64 bit machines.
Can some body help me on this?
Sridhar
Re: GEF binaries for 64 bit eclipse [message #643600 is a reply to message #643534] Tue, 07 December 2010 15:37 Go to previous messageGo to next message
Originally posted by: qualle2008.gmail.com
On 07.12.10 11:02, sridhar wrote:
> Sridhar
GEF can be installed with the menu Help/Install New Software/GEF SDK.
Re: GEF binaries for 64 bit eclipse [message #644229 is a reply to message #643600] Fri, 10 December 2010 04:33 Go to previous messageGo to next message
I have downloaded GEF 3.6.1 binaries from the eclipse download site and I was able to install the binaries properly without any problem.
My question is whether to use same binaries if I am building a new plugin in eclipse- 64 bit ide. I need to build a plugin in eclipse-64 bit ide.
Sridhar
Re: GEF binaries for 64 bit eclipse [message #644385 is a reply to message #644229] Fri, 10 December 2010 18:54 Go to previous messageGo to next message
Alexander Nyssen is currently offline Alexander NyssenFriend
Hi Sridhar,
GEF is platform independent, so you may use the same binaries.
Cheers
Alexander
Re: GEF binaries for 64 bit eclipse [message #647880 is a reply to message #644385] Mon, 10 January 2011 10:07 Go to previous message
Thanks for the information.
Sridhar
Previous Topic:draw2d interaction sequence
Next Topic:serialize GEF Diagram
Current Time: Fri Apr 27 08:58:56 GMT 2018
Powered by FUDForum. Page generated in 0.01754 seconds
