Home » Eclipse Projects » Remote Application Platform (RAP) » RAP deployed in embedded tomcat - work folder sige increases huge(RAP deployed in tomcat - work folder size increases huge)
RAP deployed in embedded tomcat - work folder sige increases huge [message #643532] Tue, 07 December 2010 09:49 Go to next message
Ravi Kumar S is currently offline Ravi Kumar SFriend
Hi Everybody,
When RAP application is deployed to Embedded tomcat the work folder size increases a lot like 200 MB, 300MB etc. The more the application is accessed it increases the size of the work folder.
Right now the workaround or handling this is only by restarting the tomcat and have a script to delete the work folder.
Anybody has a solution please let me know?
Ravi
Re: RAP deployed in embedded tomcat - work folder sige increases huge [message #643891 is a reply to message #643532] Wed, 08 December 2010 16:01 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Ravi,
did you inspect which files/folders are created with every access that
cause this issue?
Best,
Ivan
On 07.12.2010 11:49 AM, Ravi Kumar S wrote:
> Hi Everybody,
> Thanks
> Ravi
Re: RAP deployed in embedded tomcat - work folder sige increases huge [message #645232 is a reply to message #643891] Thu, 16 December 2010 07:08 Go to previous messageGo to next message
Hi Ivan,
I observed that the eclipse/configuration/osgi/bundles is the directory which grows. It has libraries of the project placed under 1,2,3,4,5 folders separately. This folder number 1 or 2 or 3 represents the session.
So if there are 20 sessions then there will be 20th folder created and have all libraries available in that folder under .cp/lib folder.
Looks like this is the reason for the work folder size increase.
Ravi
Re: RAP deployed in embedded tomcat - work folder sige increases huge [message #645241 is a reply to message #645232] Thu, 16 December 2010 08:31 Go to previous message
Hi Ravi,
I didn't test it with Embedded tomcat, but on the external tomcat
(Windows) I don't observe such problems.
Best,
Ivan
On 16.12.2010 9:08 AM, Ravi Kumar S wrote:
> Hi Ivan,
> Thanks
> Ravi
Previous Topic:Single source and Internationalization
Next Topic:GMap custom widget
Current Time: Thu Apr 26 01:35:25 GMT 2018
Powered by FUDForum. Page generated in 0.01989 seconds
