Home » Modeling » Modeling (top-level project) » how to adapt the generated objectsI have
how to adapt the generated objectsI have [message #643502] Tue, 07 December 2010 02:28 Go to next message
Tom H is currently offline Tom H
I have some EMF generated objects from an xsd and now have lots of classes like
Type1Request
Type2Request
Type3Request
Type4Request
Type5Request
I need to adapt those objects to a local interface called IMyRequest which specifies how to do something with the request objects
really I just want to check the type of the object and add a method to it, if it one of the classes above, something like;
public RequestAdapter(){
void RequestAdapter(EObject req){
switch(EObject)
case Type1Request :
case Type2Request::
case Type3Request::
case Type4Request:
//all is well
case SomeOtherObject:
throw NotSupportedException;
break;
public string process(){
do something here//
What pattern should I be looking at?
I am confused by EMF adapter patterns as they seem to be orientated towards adding notifications to objects rather than extra functionality.
Any suggestions would be welcome.Thanks
T
[Updated on: Tue, 07 December 2010 02:30]
Report message to a moderator
Re: how to adapt the generated objectsI have [message #643641 is a reply to message #643502] Tue, 07 December 2010 12:59 Go to previous message
Ed Merks is currently offline Ed Merks
Tom,
You could do it in the usual Java way with a bunch of instanceof tests
or use the generated switch. Look at the modelSwitch of the generated
XyzAdapterFactory as a good example.
> classes like
> Type1Request
> Type2Request
> Type3Request
> Type4Request
> Type5Request
> really I just want to check the type of the object and add a class to
> switch(EObject)
> case Type1Request :
> case Type2Request::
> case Type3Request::
> case Type4Request:
> //all is well
> break;
> do something here//
Previous Topic:generics in ecore model
Next Topic:what is the difference between EMF, UML ,Protege and MetaEdit+
Current Time: Sat May 25 06:16:48 EDT 2013
Powered by FUDForum. Page generated in 0.08277 seconds
