Home » Language IDEs » Java Development Tools (JDT) » IDL compiler plugin for Eclipse(setup for compiling IDL file's from Eclipse )
IDL compiler plugin for Eclipse [message #643498] Tue, 07 December 2010 07:03
Srikanth V is currently offline Srikanth VFriend
HI All
i have a java project, i have setup my project in the eclipse. I also have some of the IDL files in my project, i need to compile these IDL files from Eclipse. When i check in the net, i found that i could use plugins "ORB STUDIO 7" or "the eclipse corba plugin(ECP)" for compiling the IDL files from the eclipse. I downloaded the ECP plugin to my eclipse but when i try to set the compiler i am unable to edit the option, also i didnt find the download path for the ORB STUDIO 7. Can any one of you suggest me why i am not able to edit the compiler option for ECP or provide me a download path for the ORB STUDIO 7 or suggest if there is any other option.
Previous Topic:Dialog name for the Ctrl-f6 in eclipse
Next Topic:Linke to folder in teh file system - problem
Current Time: Tue Mar 20 18:01:19 GMT 2018
Powered by FUDForum. Page generated in 0.02186 seconds
