Home » Eclipse Projects » Riena » Riena Security - Session is null at some calls
Riena Security - Session is null at some calls [message #643497] Tue, 07 December 2010 06:54 Go to next message
Originally posted by: matthiasrodler.gmx.net
I'm using Riena Security and I'm currently facing the problem, that at
some calls I get a null value from the SessionHolder within the
SecurityCallHook.
The problem will occur at every service call within a
org.eclipse.core.runtime.jobs.Job class (in the run method) but I'm not
sure if this is the reason (but it seems so).
At any further calls - outside a job - the session is set again.
Matthias
Re: Riena Security - Session is null at some calls [message #644102 is a reply to message #643497] Thu, 09 December 2010 13:33 Go to previous messageGo to next message
Christian Campo is currently offline Christian CampoFriend
Hi Matthias,
the session in the SessionHolder is a singleton on the client. So no matter what thread you are in, it should always be
available once you have logged in successfully.
Maybe it helps to set break points in SimpleSessionHolder class in setHolder and getHolder to see whats going on in your
environment. It should certainly work.
christian
Am 07.12.10 07:54, schrieb Matthias Rodler:
> SecurityCallHook.
> Matthias
Re: Riena Security - Session is null at some calls [message #644534 is a reply to message #644102] Mon, 13 December 2010 06:36 Go to previous messageGo to next message
The reason for a null pointer is the usage of the help system from
eclipse and with this your way how you decide between client and server
mode.
The help system needs several packages which start with
"org.eclipse.equinox.http" for which you are looking for in the
ContainerModel class. This leads to the usage of
SimpleThreadedSessionHolder which will create a new SessionHolder if it
is called within an eclipse job.
I just have missed your "SERVER Mode" message and was not aware about
the impact the mode decision has on the application.
Maybe a "server" bundle could be used instead of looking at the bundle
names.
Matthias
Am 09.12.2010 14:33, schrieb Christian Campo:
> Hi Matthias,
> matter what thread you are in, it should always be available once you
> setHolder and getHolder to see whats going on in your environment. It
> christian
>> SecurityCallHook.
>> Matthias
Re: Riena Security - Session is null at some calls [message #644548 is a reply to message #644534] Mon, 13 December 2010 08:38 Go to previous messageGo to next message
Stefan Liebig is currently offline Stefan LiebigFriend
Hi Matthias,
That´s right. It is not a very save way for deciding whether we are on
the server or the client. But it is the fallback if the system property
"riena.container.type" is not set.
==> http://wiki.eclipse.org/Riena_System_Properties
Tschüß,
Stefan
Am 13.12.2010 07:36, schrieb Matthias Rodler:
> mode.
> names.
> Matthias
>> Hi Matthias,
>> christian
>>> Hi,
>>> SecurityCallHook.
>>> Matthias
Re: Riena Security - Session is null at some calls [message #644580 is a reply to message #644548] Mon, 13 December 2010 10:52 Go to previous message
I have added the use case of Security to the wiki page for the riena.container.type system property.....
christian
Am 13.12.10 09:38, schrieb Stefan Liebig:
> Hi Matthias,
> Tschüß,
> Stefan
>> mode.
>> names.
>> Matthias
>>> Hi Matthias,
>>> christian
>>>> Hi,
>>>> SecurityCallHook.
>>>> Matthias
Previous Topic:Riena Remote Services OSGi EE compliant using ECF
Next Topic:How to implement Remote Observer Pattern with Riena?
Current Time: Thu Apr 26 04:17:50 GMT 2018
Powered by FUDForum. Page generated in 0.02370 seconds
