Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE(error in running the PDE)
PDE [message #643459] Mon, 06 December 2010 23:06 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
package org.eclipse.examples.helloworld;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.swt.widgets.Shell;
/** HelloWorldAction is a simple example of using an
* action set to extend the Eclipse Workbench with a menu
* and toolbar action that prints the "Hello World" message.
public class HelloWorldAction implements IWorkbenchWindowActionDelegate {
IWorkbenchWindow activeWindow = null;
/** Run the action. Display the Hello World message
public void run(IAction proxyAction) {
// proxyAction has UI information from manifest file (ignored)
Shell shell = activeWindow.getShell();
MessageDialog.openInformation(shell, "Hello World", "Hello World!");
// IActionDelegate method
public void selectionChanged(IAction proxyAction, ISelection selection) {
// do nothing, action is not dependent on the selection
// IWorkbenchWindowActionDelegate method
public void init(IWorkbenchWindow window) {
activeWindow = window;
public void dispose() {
// nothing to do
the above is the code of my plugin. i want to create hello plugin but it generates the error that applet not initialized.
what should i do please help me.
thanks for your time!
Re: PDE [message #643506 is a reply to message #643459] Tue, 07 December 2010 07:10 Go to previous message
Daniel Krügler is currently offline Daniel KrüglerFriend
> * action set to extend the Eclipse Workbench with a menu * and toolbar
Why don't you start with a tutorial? I recommend to start with simples
examples from the following ones:
http://www.vogella.de/articles/Eclipse/article.html
http://www.vogella.de/articles/EclipseRCP/article.html
http://www.vogella.de/articles/EclipsePlugIn/article.html
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:about PDE
Next Topic:headless build fails - launcher fragment not found
Current Time: Sun Feb 18 03:37:34 GMT 2018
Powered by FUDForum. Page generated in 0.01900 seconds
