Home » Modeling » GMF (Graphical Modeling Framework) » Node with OPEN_ROLE EditPolicy nearly "unclickable"
Node with OPEN_ROLE EditPolicy nearly "unclickable" [message #643442] Mon, 06 December 2010 21:17 Go to next message
Kai Maschke is currently offline Kai MaschkeFriend
on some nodes I installed EditPolicyRoles with OPEN_ROLE.
It opens a swing component.
My problem is, that I have to click very very often until the command is fired. Almost every time I am double-clicking on it, the editor wants to edit the label, which is inside the node.
Can I prevent the editor of doing so?
The labels in the nodes are already read-only.
Another problem is that I'd like to have the nodes, which are inside a compartment, in "List Layout". But if I activate the "List Layout" for the parent comparment, the OPEN_ROLE event is never fired!
My nodes and compartments are very simple.
Any solutions?
Re: Node with OPEN_ROLE EditPolicy nearly "unclickable" [message #643467 is a reply to message #643442] Mon, 06 December 2010 23:49 Go to previous message
Michael Golubev is currently offline Michael GolubevFriend
In the TopGraphicalEditPart#performEditRequest there is following code:
editPart = (EditPart) getEditingDomain().runExclusive(
  new RunnableWithResult.Impl() {
     public void run() {
        setResult(getPrimaryChildEditPart());
if (editPart != null){
  editPart.performRequest(request);
so in order to disable in-place editor, you may either return null from the generated getPrimaryChildEditPart() method or override the whole performEditRequest() method.
if I activate the "List Layout" for the parent compartment, the OPEN_ROLE event is never fired
Weird, in the UML2Tools we have a top-level packages that contain inner deep packages in a list layout, but OPEN_ROLE EP works for both of them. May be the fixing of the first part will reveal something new?
Michael
Previous Topic:Can't refer to elements defined in more than one Ecore file in GMF Audit Rule
Next Topic:How to refresh the content of an external label
Current Time: Tue Jan 23 22:17:04 GMT 2018
Powered by FUDForum. Page generated in 0.01821 seconds
