| Source file not being included in a build [message #643391] |
Mon, 06 December 2010 12:21  |
Andrew Ellis Messages: 7 Registered: December 2010 |
Junior Member |
I am using Eclipse with C/C++ compiler for Jennic microcontroller.
I have added a source file to my project tree, but when I build the project the source file is not be built. I have spent a lot of time searching for inspiration to solving this problem with Google, this forum, and the included help in Eclipse, but I have been unsuccessful. The file in question is shown in the project tree. What do I need to do to ensure the source file is included in the build?
Thanks in advance
Andrew
| Re: Source file not being included in a build [message #643624 is a reply to message #643528] |
Tue, 07 December 2010 11:42   |
Junior Member |
Hi Axel,
I have used an example project where the makefile has been generated with Eclipse.
I have pasted the contents of the makefile below plus 3 other files that it references.
The file that is not being compiled is "24xx01.c", however it is listed in the file "subdir.mk" so I don't understand why it is not being compiled.
Andrew
Makefile
# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := del
# All of the sources participating in the build are defined here
-include sources.mk
-include subdir.mk
-include Common/Source/subdir.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
all: JN-AN-1061-Jenie-Application-Template\n
# Tool invocations
JN-AN-1061-Jenie-Application-Template\n: $(OBJS) $(USER_OBJS)
@echo 'Building target: $@'
@echo 'Invoking: Cygwin C Linker'
gcc -o"JN-AN-1061-Jenie-Application-Template\n" $(OBJS) $(USER_OBJS) $(LIBS)
@echo 'Finished building target: $@'
@echo ' '
# Other Targets
clean:
-$(RM) $(OBJS)$(C_DEPS)$(EXECUTABLES) JN-AN-1061-Jenie-Application-Template\n
-@echo ' '
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
sources.mk
O_SRCS :=
C_SRCS :=
S_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
OBJS :=
C_DEPS :=
EXECUTABLES :=
# Every subdirectory with source files must be described here
SUBDIRS := \
Common/Source \
objects.mk
USER_OBJS :=
LIBS :=
subdir.mk
C_SRCS += \
../Common/Source/24xx01.c \
../Common/Source/ExceptionHandler.c \
../Common/Source/RTC.c \
../Common/Source/Utils.c \
../Common/Source/adc.c \
../Common/Source/led.c \
../Common/Source/queue.c \
../Common/Source/serial.c \
../Common/Source/spi.c \
../Common/Source/time.c \
../Common/Source/uart.c \
../Common/Source/xsprintf.c
OBJS += \
./Common/Source/24xx01.o \
./Common/Source/ExceptionHandler.o \
./Common/Source/RTC.o \
./Common/Source/Utils.o \
./Common/Source/adc.o \
./Common/Source/led.o \
./Common/Source/queue.o \
./Common/Source/serial.o \
./Common/Source/spi.o \
./Common/Source/time.o \
./Common/Source/uart.o \
./Common/Source/xsprintf.o
C_DEPS += \
./Common/Source/24xx01.d \
./Common/Source/ExceptionHandler.d \
./Common/Source/RTC.d \
./Common/Source/Utils.d \
./Common/Source/adc.d \
./Common/Source/led.d \
./Common/Source/queue.d \
./Common/Source/serial.d \
./Common/Source/spi.d \
./Common/Source/time.d \
./Common/Source/uart.d \
./Common/Source/xsprintf.d
# Each subdirectory must supply rules for building sources it contributes
Common/Source/%.o: ../Common/Source/%.c
@echo 'Building file: $<'
@echo 'Invoking: Cygwin C Compiler'
gcc -I" C:\Jennic\Application\JN-AN-1151-Low-Cost-JenNet-IP-Gateway\ Gateway\Source\uip-1v0 " -I"C:\Jennic\cygwin\jennic\SDK\Platform\Common\Source" -O2 -g -Wall -c -fmessage-length=0 -MMD -MP -MF"$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -o"$@" "$<"
@echo 'Finished building: $<'
@echo ' '
[Updated on: Tue, 07 December 2010 11:43] Report message to a moderator
| Re: Source file not being included in a build [message #643985 is a reply to message #643680] |
Wed, 08 December 2010 17:44   |
Junior Member |
Hi Axel,
Thank you for your reply. I can build the other files without any problems.
I have pasted the output from the console below. I'm sorry that it's so lengthy. I don't know it it gives any clues. If not, perhaps I could email my project to you?
Andrew
**** Build of configuration Gateway for project JN-AN-1151-Low-Cost-JenNet-IP-Gateway ****
make all
rm -f xsprintf.o
rm -f ENC28J60.o
rm -f timer.o
rm -f psock.o
rm -f uip_arp.o
rm -f uip.o
rm -f ip.o
rm -f setup.o
rm -f network-device.o
rm -f httpd.o
rm -f httpd-fs.o
rm -f httpd-cgi.o
rm -f http-strings.o
rm -f clock-arch.o
rm -f uart.o
rm -f time.o
rm -f spi.o
rm -f serial.o
rm -f queue.o
rm -f RTC.o
rm -f Utils.o
rm -f Gateway.o
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/Gateway.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o Gateway.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/Gateway.c -MD -MF Gateway.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/Utils.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o Utils.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/Utils.c -MD -MF Utils.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/RTC.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o RTC.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/RTC.c -MD -MF RTC.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/queue.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o queue.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/queue.c -MD -MF queue.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/serial.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o serial.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/serial.c -MD -MF serial.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/serial.c: In function 'clear_TxBuf':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/serial.c:138: warning: cast to pointer from integer of different size
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/spi.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o spi.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/spi.c -MD -MF spi.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/time.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o time.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/time.c -MD -MF time.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/uart.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o uart.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/uart.c -MD -MF uart.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/clock-arch.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o clock-arch.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/clock-arch.c -MD -MF clock-arch.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/http-strings.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o http-strings.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/http-strings.c -MD -MF http-strings.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o httpd-cgi.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c -MD -MF httpd-cgi.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c: In function 'u8UpdateTableEntry':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:139: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:143: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:146: warning: format '%08X' expects type 'unsigned int', but argument 4 has type 'uint64'
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:146: warning: format '%08X' expects type 'unsigned int', but argument 5 has type 'uint64'
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:148: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:154: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:159: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:166: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:171: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:175: warning: dereferencing 'void *' pointer
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:176: warning: format '%d' expects type 'int', but argument 4 has type 'uint32'
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-cgi.c:178: warning: dereferencing 'void *' pointer
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o httpd-fs.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c -MD -MF httpd-fs.d -MP
In file included from /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c:44:
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fsdata.c:173: warning: pointer targets in initialization differ in signedness
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fsdata.c:175: warning: pointer targets in initialization differ in signedness
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd.c ...
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c: In function 'httpd_fs_open':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c:81: warning: dereferencing type-punned pointer will break strict-aliasing rules
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o httpd.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd.c -MD -MF httpd.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c: In function 'httpd_fs_count':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd-fs.c:120: warning: dereferencing type-punned pointer will break strict-aliasing rules
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd.c: In function 'handle_connection_cs':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/httpd.c:409: warning: passing argument 2 of 'b24xx01_Write' makes pointer from integer without a cast
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/network-device.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o network-device.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/network-device.c -MD -MF network-device.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/setup.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o setup.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/setup.c -MD -MF setup.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ip.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o ip.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ip.c -MD -MF ip.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o uip.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip.c -MD -MF uip.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip.c: In function 'uip_process':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip.c:1849: warning: label 'ip_send_nolen' defined but not used
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip.c:1446: warning: will never be executed
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip_arp.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o uip_arp.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/uip_arp.c -MD -MF uip_arp.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o psock.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c -MD -MF psock.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c: In function 'psock_send':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c:187: warning: pointer targets in assignment differ in signedness
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c: In function 'psock_readto':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c:275: warning: pointer targets in passing argument 2 of 'buf_setup' differ in signedness
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c: In function 'psock_readbuf':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c:302: warning: pointer targets in passing argument 2 of 'buf_setup' differ in signedness
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c: In function 'psock_init':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/psock.c:333: warning: pointer targets in passing argument 2 of 'buf_setup' differ in signedness
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/timer.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o timer.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/uip-1v0/uip/timer.c -MD -MF timer.d -MP
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ENC28J60.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o ENC28J60.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ENC28J60.c -MD -MF ENC28J60.d -MP
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ENC28J60.c: In function 'bENC28J60_Init':
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ENC28J60.c:435: warning: will never be executed
/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Gateway/Source/ENC28J60.c:433: warning: will never be executed
Compiling /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/xsprintf.c ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -c -o xsprintf.o -DJN514x=5140 -DJN5148=5148 -msibcall -mno-entri -mno-multi -mno-setcc -mno-cmov -mno-carry -mno-subb -mno-sext -mno-ror -mno-hard-div -mhard-mul -mbranch-cost=3 -msimple-mul -march=ba2 -mredzone-size=4 -ffixed-r16 -ffixed-r17 -ffixed-r18 -ffixed-r19 -ffixed-r20 -ffixed-r21 -ffixed-r22 -ffixed-r23 -ffixed-r24 -ffixed-r25 -ffixed-r26 -ffixed-r27 -ffixed-r28 -ffixed-r29 -ffixed-r30 -ffixed-r31 -fomit-frame-pointer -Os -fdata-sections -ffunction-sections -DWATCHDOG_ENABLED -DJENNIC_CHIP=JN5148 -DJENNIC_CHIP_FAMILY=JN514x -Wall -Wunreachable-code -I/cygdrive/c/Jennic/Platform/Common/Include -I/cygdrive/c/Jennic/Platform/DK2/Include -I/cygdrive/c/Jennic/Components/Common/Include -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/uip-1v0/uip -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Gateway/Source/.. -I/cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet- IP-Gateway/Common/Source -I/cygdrive/c/Jennic/Components/JennicLogo/Include -I/cygdrive/c/Jennic/Components/Utilities/Include -I/cygdrive/c/Jennic/Components/AppQueueApi/Include -I/cygdrive/c/Jennic/Components/JenNet/Include -I/cygdrive/c/Jennic/Components/Jenie/Include -I/cygdrive/c/Jennic/Components/AppApi/Include -I/cygdrive/c/Jennic/Components/HardwareApi/Include -I/cygdrive/c/Jennic/Components/MAC/Include -I/cygdrive/c/Jennic/Components/TimerServer/Include -I/cygdrive/c/Jennic/Components/Random/Include /cygdrive/c/Jennic/Application/JN-AN-1151-Low-Cost-JenNet-IP -Gateway/Common/Source/xsprintf.c -MD -MF xsprintf.d -MP
Linking Gateway_JN5148.elf ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-gcc -Wl,--gc-sections -Wl,-u_AppColdStart -Wl,-u_AppWarmStart -TApp_Stack_Size.ld -nostartfiles -mba2_elf -march=ba2 -L/cygdrive/c/Jennic/Chip/JN5148/Build -L/cygdrive/c/Jennic/Chip/JN5148/Library -L/cygdrive/c/Jennic/Platform/DK2/Library -L/cygdrive/c/Jennic/Components/Library -L/cygdrive/c/Jennic/Stack/JenNet/Build -TAppBuild_JN5148.ld -o Gateway_JN5148.elf Gateway.o Utils.o RTC.o queue.o serial.o spi.o time.o uart.o clock-arch.o http-strings.o httpd-cgi.o httpd-fs.o httpd.o network-device.o setup.o ip.o uip.o uip_arp.o psock.o timer.o ENC28J60.o xsprintf.o -Wl,--start-group -lJenieCR_JN514x -lMacPatch_JN5148 -lHWPatch_JN5148 -lBoardLib_JN514x -Wl,--end-group -Wl,-Map,Gateway_JN5148.map
Generating binary ...
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-size Gateway_JN5148.elf
text data bss dec hex filename
44239 1392 17524 63155 f6b3 Gateway_JN5148.elf
/cygdrive/c/Jennic/Tools/ba-elf-ba2/bin/ba-elf-objcopy -j .flashheader -j .oad -j .mac -j .heap_location -j .rtc_clt -j .rodata -j .data -j .text -j .bss -j .heap -j .stack -S -O binary Gateway_JN5148.elf Gateway_JN5148.bin
| Re: Source file not being included in a build [message #644039 is a reply to message #643985] |
Thu, 09 December 2010 03:32   |
Axel Mueller Messages: 1830 Registered: July 2009 |
The build output does not correspond to the Makefile you posted last time. E.g. Gateway.c is not mentioned in your Makefile and the files adc.c and ed.c that are listed in the Makefile are not build.
I am also missing the message "Invoking: Cygwin C Compiler" from Eclipse makefile.
I guess you are invoking the wrong Makefile from Eclipse. In Project Properties->C/C++ Build you can define the location of the Makefile ("build location"). Usually it is the root folder of your project (depends on the build configuration!).
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
FUDForum. Page generated in 0.02149 seconds
