Home » Newcomers » Newcomers » Source file not being included in a build
Source file not being included in a build [message #643202] Mon, 06 December 2010 01:25 Go to next message
Andrew Ellis is currently offline Andrew EllisFriend
I am using Eclipse with C/C++ compiler for Jennic microcontroller.
I have added a source file to my project tree, but when I build the project the source file is not be built. I have spent a lot of time searching for inspiration to solving this problem but I have been unsuccessful. The file in question is shown in the project tree. What do I need to do to ensure the source file is included in the build?
Thanks in advance
Andrew
Re: Source file not being included in a build [message #643218 is a reply to message #643202] Mon, 06 December 2010 04:40 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Sticky post at the top of this forum:
http://www.eclipse.org/forums/index.php?t=msg&th=161206& amp;start=0&S=c89e3369de31210df06da94abcf6411d
On 2010.12.05 18:26, Andrew Ellis wrote:
> Thanks in advance
> Andrew
Re: Source file not being included in a build [message #643325 is a reply to message #643218] Mon, 06 December 2010 14:08 Go to previous messageGo to next message
Hi Russell,
Thank you for your reply.
Unfortunately it does not help me. As I stated in my original message I have spent a lot of time searching for the answer. To be more specific, I have searched this site, used Google and the help facility within Eclipse. However all that has happened is that I have been going round in circles. I have used search terms such as "adding files to an eclipse project" and "adding files to a make file in eclipse", unfortunately these have not yielded the answer.
I'm sorry if this seems a repetitive question, but I really cannot find the answer anywhere else, despite my best efforts. Could some one please direct me to a link that may answer my question, or explain what I am doing wrong.
Thanks in advance
Andrew
[Updated on: Mon, 06 December 2010 14:08]
Report message to a moderator
Re: Source file not being included in a build [message #643387 is a reply to message #643325] Mon, 06 December 2010 16:52 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
On 12/6/10 9:08 AM, Andrew Ellis wrote:
> Hi Russell,
> Unfortunately it does not help. Me. As I stated in my original message I
> Eclipse. However all that has happen is that I have been going round in
> doing wrong.
What Russ was trying to tell you by pointing to the sticky post was that
you should ask on the CDT forum group; most of the C/C++ gurus hang out
there instead of in this "newcomers" group.
Eric
Re: Source file not being included in a build [message #643389 is a reply to message #643387] Mon, 06 December 2010 17:19 Go to previous message
Ok.
I think I am being a bit dumb, Sorry to be a nuisance.
Andrew
Previous Topic:How extended html Tags
Next Topic:Compare CSV Files as ASCII
Current Time: Tue Jan 23 17:50:13 GMT 2018
Powered by FUDForum. Page generated in 0.02696 seconds
