Home » Modeling » M2T (model-to-text transformation) » execute an accelo plugin directly in the shell
execute an accelo plugin directly in the shell [message #642686] Thu, 02 December 2010 11:03 Go to next message
smaoui asma is currently offline smaoui asmaFriend
Member
I built a compiler that needs to look at the MyClass file generated by an acceleo project.
I need to add the acceleo stuff in my compiler makefile,
In the shell, I will call my compiler that calls the Acceleo project to generate the file MyClass.
Is it possible ? if yes, can you explain what should I add to my compiler makefile,
I tried to run Acceleo in standlone (by running it as a java application) and compiling this java application in my makefile (calling javac, ...) but my model contains profile and I did not succed in loading it.
thanks
Asma
Re: execute an accelo plugin directly in the shell [message #643496 is a reply to message #642686] Tue, 07 December 2010 06:56 Go to previous message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
I've never tried to load a model with profiles so I would advise you to ask your question in the EMF forum.
Stephane Begaudeau, Obeo.
Previous Topic:[Check] invoke programmatically
Next Topic:[Acceleo 3.1.0M3] install site.xml
Current Time: Tue May 22 02:44:45 GMT 2018
Powered by FUDForum. Page generated in 0.02050 seconds
