Home » Newcomers » Newcomers » Eclipse/ADT/NDK Native Libraries Don't Build(Android SDK/NDK via Eclipse, ADT/NDK/Sequoyah plug-in(s))
icon5.gif  Eclipse/ADT/NDK Native Libraries Don't Build [message #642591] Wed, 01 December 2010 21:57 Go to next message
Paul Lamb is currently offline Paul LambFriend
Hello, all. Sorry if this isn't the correct section to post, but I could not find a section related to Android plugins for Eclipse. I'm hoping that perhaps there are other Eclipse Android developers on here that might be able to help me out. Moderators, feel free to move this to a more appropriate section if there is one.
I'm still new to the NDK and Eclipse, so this is probably an easy question. I have source code for several libraries that I want to have built into libs/armeabi/libNAME.so. Reading the documentation, it seems like all I should have to do is put the libraries into individual folders under the jni folder, create an Android.mk file in jni which has a call to "include $(call all-subdir-makefiles)", and another Android.mk in the sub-folder which has a call to "include $(BUILD_SHARED_LIBRARY)" I think these files are correct, so I'm not sure what I'm missing to have Eclipse/NDK actually build the libraries.
For reference, the Android.mk file located in jni is:
# If SDL_Mixer should link to libMAD
SDL_MIXER_USE_LIBMAD :=
ifneq ($(strip $(filter mad, $(COMPILED_LIBRARIES))),)
SDL_MIXER_USE_LIBMAD := 1
endif
ifneq ($(findstring -crystax,$(TARGET_CC)),)
$(info Building with CrystaX toolchain - RTTI and exceptions enabled, STLPort disabled)
CRYSTAX_TOOLCHAIN=1
endif
And an example of an Android.mk file for one of the libraries, located in a sub-folder under jni:
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE := xml2
LOCAL_CFLAGS := -Os -I$(LOCAL_PATH) -I$(LOCAL_PATH)/include
LOCAL_CPP_EXTENSION := .cpp
LOCAL_SRC_FILES := \
    SAX.c entities.c encoding.c error.c \
    parserInternals.c parser.c tree.c hash.c list.c xmlIO.c \
    xmlmemory.c uri.c valid.c xlink.c HTMLparser.c HTMLtree.c \
    debugXML.c xpath.c xpointer.c xinclude.c nanohttp.c nanoftp.c \
    DOCBparser.c catalog.c globals.c threads.c c14n.c xmlstring.c \
    xmlregexp.c xmlschemas.c xmlschemastypes.c xmlunicode.c \
    xmlreader.c relaxng.c dict.c SAX2.c xmlwriter.c legacy.c \
    chvalid.c pattern.c xmlsave.c xmlmodule.c schematron.c \
    triostr.c trio.c trionan.c
LOCAL_SHARED_LIBRARIES :=
LOCAL_STATIC_LIBRARIES :=
LOCAL_LDLIBS := -lz -ldl
Let me know if you require any further information (sorry if I've left out something obvious).
Re: Eclipse/ADT/NDK Native Libraries Don't Build [message #642604 is a reply to message #642591] Wed, 01 December 2010 22:52 Go to previous messageGo to next message
Aha! I figured it out - I just needed to select Android Tools->Add Native Support. I knew it would be something simple.
Re: Eclipse/ADT/NDK Native Libraries Don't Build [message #642612 is a reply to message #642591] Thu, 02 December 2010 00:46 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
> hoping that perhaps there are other Eclipse Android developers on here.
> [snip]
No, the Android SDK contains plug-ins for use with Eclipse and not the
other way around. For some forums, see:
http://www.javahotchocolate.com/tutorials/android.html#suppo rt
Yes, there are lots of us, but we refrain from too much Android
discussion because this isn't really the forum (and, as I say, there
isn't an Android forum at eclipse.org; the topic is very well covered by
other forums already).
There's a great tutorial that would have told you the answer to this at
http://www.vogella.de/articles/Android/article.html
Best of luck.
Previous Topic:MyEclipse or Eclipse WTP?
Next Topic:A to Z Programming
Current Time: Tue May 22 02:52:57 GMT 2018
Powered by FUDForum. Page generated in 0.03635 seconds
