| Re: How to tell eclipse that my makefile is in a subdirectory? [message #64573 is a reply to message #64549] |
Mon, 17 March 2003 20:47   |
Originally posted by: skendall.theedge.ca
I am not sure if there is a better way to do this, but I just put a
basic makefile in the project root that calls my makefiles in the subdirs.
all: sources
sources:
$(MAKE) -C src
Hopefull that should work.
Sid
Markus Karg wrote:
> Eclipse CDT assumes the makefile to be named makefile and to be found in the
> root directory of the project. How can I tell adjust eclipse in a way that
> allows me to have the makefile in a subdirectory and that it has a different
> name?
> Thanks
> Markus
| Re: How to tell eclipse that my makefile is in a subdirectory? [message #64594 is a reply to message #64549] |
Mon, 17 March 2003 20:59   |
Originally posted by: javacard.hotmail.com
hi,
you can use subdir's makefile after you specified the following in
current makefile:
all install clean:
make -C src/appdir $@
> name?
> Thanks
> Markus
| Re: How to tell eclipse that my makefile is in a subdirectory? [message #65032 is a reply to message #64594] |
Mon, 24 March 2003 04:13   |
Originally posted by: okoltermann.gmx.de
I think that in an older Eclipse version (maybe even 1.0) I was able
to select any subdir of the project and select Build in the context
menu to run the makefile in that directory. But memory fades and it's
true that this functionality has gone. Does somebody know anything
about this?
bye,
OK.
| Re: How to tell eclipse that my makefile is in a subdirectory? [message #66225 is a reply to message #65181] |
Tue, 08 April 2003 05:19  |
"Chad Yates" <cyates@uidaho.edu> writes:
> You can do it in 2.0 also.
How? If I try it now it always tries to run make in the projects root
dir. Could this be QNX specific - I'm using QNX Momentics 6.2.1? (It's
saying Eclipse 2.0.2)
Would be very interested in this, bye,
OK.
FUDForum. Page generated in 0.02294 seconds
