Home » Modeling » M2T (model-to-text transformation) » [Xpand] Merging several models into one output (file)(How can I create one output file contains informations from more than one model?)
[Xpand] Merging several models into one output (file) [message #641842] Sun, 28 November 2010 17:13 Go to next message
Michael Lindner is currently offline Michael LindnerFriend
I've got the following DSL written in Xtext:
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
generate mydsl "http://www.test.de/mydsl/MyDsl"
MyModel:
   'mymodel' name=ID '{'
      allSubsystem+=Subsystem*
Subsystem:
   name=ID '{'
      (messages="messages" '{'
        allMessage+=Message*
Message:
   'error' name=ID (allLanguage+=MessageLang (','? allLanguage+=MessageLang)* )
MessageLang:
    lang=MessageLanguage '=>' message=STRING
enum MessageLanguage:   DE | EN;
My default workflow looks like this:
Workflow {
  component = org.eclipse.xtext.mwe.Reader {
    // lookup all resources on the classpath
    useJavaClassPath = true
    // or define search scope explicitly
    path = modelPath
    // this class will be generated by the xtext generator
    register = de.db.kolt.ribdsl.RibDslStandaloneSetup {}
    load = {
      slot = "allMyModel"
      type = "MyModel"
  component = org.eclipse.xpand2.Generator {
    expand = "templates::Main::processMain FOREACH allMyModel"
    outlet = {
      path = targetDir
    fileEncoding = fileEncoding
Not really spectacular. But now my question. If I run the workflow and my Xpand file looks like this
«DEFINE processMain FOR MyModel-»
  «EXPAND processMessage»
«ENDDEFINE»
«DEFINE processMessage FOR MyModel»
  «FILE "messages.properties"»
    «FOREACH allSubsystem.allMessage AS message»
      «FOREACH message.allLanguage AS entry»
        «REM»the entry is unique by the name of the subsystem + "." + name of the mesage«ENDREM»
        «((Subsystem)message.eContainer()).name».«message.name»=«entry.message»
       «ENDFOREACH»
    «ENDFOREACH»
  «ENDFILE»
«ENDDEFINE»
the generator only produces one output file with the first model of one file. But I have more than one file in my source-directory. In every file (model) are several messages.
Who can I create only one output file ("messages.properties") which contains all messages from all models out of many files?
Than you
Michael
Re: [Xpand] Merging several models into one output (file) [message #641850 is a reply to message #641842] Sun, 28 November 2010 18:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hello michael, there are two ways to solve this:
(1) restructure the templates
Workflow {
    path = modelPath
    load = {
      slot = "allMyModel"
      type = "MyModel"
    expand = "templates::Main::processMain FOR allMyModel"
    outlet = {
      path = targetDir
«DEFINE processMain FOR List[MyModel]-»
  «EXPAND processMainElement FOREACH this»
  «ENDFILE»
«ENDDEFINE»
«DEFINE processMainElement FOR MyModel-»
«ENDDEFINE»
       «ENDFOREACH»
    «ENDFOREACH»
«ENDDEFINE»
(2) change the configuration of the outlet
		expand = "templates::Template::main FOREACH greetings"
		outlet = {
			path = targetDir
			append = true
If you have other generated artefacts that should no be appended just create another outlet
		outlet = {
			path = targetDir
		outlet = {
			path = targetDir
			append = true
			name = "ANAME"
«FILE "test.txt" ANAME»
«name»
«ENDFILE»
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: [Xpand] Merging several models into one output (file) [message #641852 is a reply to message #641850] Sun, 28 November 2010 18:49 Go to previous message
Hi Christian,
this is very helpful. I'll check the two possibilities and look, which way is the best one (for my use case).
Michael
Previous Topic:[Xpand / Xtend] typeSelect() on stereotype does not work
Next Topic:eAllContents gone ...
Current Time: Sat May 26 00:38:55 GMT 2018
Powered by FUDForum. Page generated in 0.02163 seconds
