Home » Language IDEs » C / C++ IDE (CDT) » cdt running error(eclipse cdt won't run my c++ project)
cdt running error [message #641730] Sat, 27 November 2010 09:48 Go to next message
Hannes Vandecasteele is currently offline Hannes VandecasteeleFriend
Hi all,
I made som simple test program in eclipse cdt and compiled it. That works fine. code:
#include <iostream>
int main( ) {
	std::cout<<"";
	std::cout<<"print this.";
	return 0;
If i want to run the program, it doesn't print out anything. But, if i run it from the cmd or in netbeans, it all works fine. Also, when i want to debug the project, it doesn't work either, but it does in netbeans( error: "No source available for "main() at 0x4013d7" ")
Any ideas to fix this?
hannesvdc
Re: cdt running error [message #641902 is a reply to message #641730] Mon, 29 November 2010 08:30 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
I guess you are working on Windows. There is a known problem with the console output. See
http://wiki.eclipse.org/CDT/User/FAQ#Eclipse_console_does_no t_show_output_on_Windows
Did you build with debug info enabled?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: cdt running error [message #642036 is a reply to message #641730] Mon, 29 November 2010 15:52 Go to previous messageGo to next message
Thanks for replly!
I added the following lines to my code:
setvbuf(stdout, NULL, _IONBF, 0);
setvbuf(stderr, NULL, _IONBF, 0);
But i got the following errors:
../main.cpp:11:10: error: 'stdout' was not declared in this scope
../main.cpp:11:24: error: '_IONBF' was not declared in this scope
../main.cpp:11:33: error: 'setvbuf' was not declared in this scope
../main.cpp:12:10: error: 'stderr' was not declared in this scope
For debugging, what is 'build debug info enabled'?
hannesvdc
Re: cdt running error [message #642162 is a reply to message #642036] Tue, 30 November 2010 08:08 Go to previous messageGo to next message
Hannes Vandecasteele wrote on Mon, 29 November 2010 16:52
Thanks for replly!
hannesvdc
You need #include <stdio.h> for setvbuf
Did you build a Debug or Release version?
Before you ask
- search this forum
- google
Re: cdt running error [message #642284 is a reply to message #641730] Tue, 30 November 2010 16:56 Go to previous message
It still doesn't work, this is my code:
#include <iostream>
#include <stdio.h>
int main( ) {
	std::cout<<"";
	return 0;
Currently, debug is the active configuration.
hannesvdc
Previous Topic:Organizing code by refactoring classes into sub folders
Next Topic:0x0-Window when debugging
Current Time: Sat May 26 12:10:00 GMT 2018
Powered by FUDForum. Page generated in 0.01575 seconds
