Home » Eclipse Projects » Remote Application Platform (RAP) » Widget's border theming
Widget's border theming [message #639639] Wed, 17 November 2010 10:17 Go to next message
Massimo Zugno is currently offline Massimo ZugnoFriend
Hi, I'm trying to theme a widget's border applying different border widths for the same border. The theming reference state that this is not possible since border-width accept a <dimension> as value (and not a <box-dimension>). Is there a way to workaround this issue?
Thanks in advance, Massimo.
[Updated on: Wed, 17 November 2010 10:18]
Report message to a moderator
Re: Widget border theming [message #639687 is a reply to message #639639] Wed, 17 November 2010 13:32 Go to previous message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi!
There is a bug to enable this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283872 It has a patch
for a workaround attached, but its very limited. I don't see this beeing
fixed anytime soon, since it would require changes to many existing widgets.
Greetings,
Tim
Previous Topic:How to display tooltips for its content in the tableviewer
Next Topic:Require-Bundle: org.eclipse.rap.ui not found
Current Time: Mon Feb 19 02:32:05 GMT 2018
Powered by FUDForum. Page generated in 0.01816 seconds
