| [Solved] Deleting a Workspace or Project [message #638892] |
Fri, 12 November 2010 18:15  |
Rico Messages: 6 Registered: November 2010 |
Junior Member |
I posted this in the Newcomers section but realized it may be a more advanced topic. Sorry about the double post.
I'm getting the dreaded "overlaps the location of another project:" problem.
I've searched up and down for a solution to this and can't seem to find one.
I've been trying to get subversive to work and read that all I needed to do was start a new project with code that had all the .svn stuff in it and subversive would recognize it. After I created the project I noticed it wasn't a C++ project. I couldn't figure out how to convert it so I decided to delete it.
I didn't remove the folder/files from the HDD but just from the IDE window.
So, I decided to try and create a new C++ project and see if it would work. I can't do it because of this stupid problem.
Is there an easy way to delete a workspace or project in Eclipse?
Don't point me to some blog about how /usr/lib/eclipse/configuration/.setting blah, blah, blah because that file doesn't exist on my machine.
I'm using Kubuntu 10.10 with Eclipse 3.5.2. Apparently they removed the convert wizard in this release and where the .setting file is.
Is there a way to delete a workspace or project WITHIN the Eclipse IDE (GUI)?
If not - there should be because this is completely ridiculous.
[Updated on: Tue, 16 November 2010 10:57] Report message to a moderator
| Re: Deleting a Workspace or Project [message #638964 is a reply to message #638892] |
Sat, 13 November 2010 23:33   |
Originally posted by: bruce.ring.sbcglobal.net
Did you try deleting the .metadata directory in the workspace directory?
"Rico" <rico.moss@gmail.com> wrote in message
news:ibkhk1$3mp$1@news.eclipse.org...
> problem.
> one.
> to delete it.
> window.
> (GUI)?
| Re: Deleting a Workspace or Project [message #639066 is a reply to message #638892] |
Mon, 15 November 2010 03:09   |
Axel Mueller Messages: 1820 Registered: July 2009 |
You cannot delete a complete workspace from within Eclipse. You have to do this on the actual file system. As mentioned in the last post all the Eclipse workspace data is stored in the directory .metadata in the workspace directory. If you delete this directory Eclipse will not longer recognize it as a workspace folder.
Projects can be deleted within Eclipse. Just select the project and choose delete. If you want to completely remove it from your harddisk you have to select "Delete project contents on disk" in the appearing dialogue.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
FUDForum. Page generated in 0.01710 seconds
