Home » Eclipse Projects » GEF » [Zest] All the nodes are in the upper left corner - please help
[Zest] All the nodes are in the upper left corner - please help [message #638846] Fri, 12 November 2010 18:23 Go to next message
William Koscho is currently offline William KoschoFriend
I am using a Zest GraphViewer, with a ContentProvider and LabelProvider and set my layout to RadialLayout. Everything displays fine the first time.
However, when I update the underlying model the ContentProvider gets notified and then calls refresh on the GraphView.
When it re-displays, all the nodes are in the upper left corner, on top of each other.
Any ideas why this is happening?
Thanks in advance,
Bill
Re: [Zest] All the nodes are in the upper left corner - please help [message #642315 is a reply to message #638846] Tue, 30 November 2010 18:52 Go to previous message
Johan Schulz is currently offline Johan SchulzFriend
You have to call applyLayout() on your GraphViewer reference. I use this helper method to refresh my UI after a model change occured.
private void updateGraph()  {
    this.viewer.refresh();
    this.viewer.applyLayout();
All new nodes move (nicely animated) from the upper left corner to their final position.
Johan
Previous Topic:How can I have a Draw2d button event start a request ?
Next Topic:Drag-drop and embed (refer) one diagram in another
Current Time: Fri May 25 11:11:31 GMT 2018
Powered by FUDForum. Page generated in 0.01527 seconds
