Home » Eclipse Projects » Linux Tools Project » problem installing C/C++ Call Graph Visualization(problem installing C/C++ Call Graph Visualization)
problem installing C/C++ Call Graph Visualization [message #638637] Thu, 11 November 2010 21:30 Go to next message
Mohsen Bayat Sarmadi is currently offline Mohsen Bayat SarmadiFriend
hi there
dear friends
i have problem installing C/C++ Call Graph Visualization and it says it is conflicting problem
Cannot complete the install because of a conflicting dependency.
Software being installed: C/C++ Call Graph Visualization (Incubation) 0.0.2.201009101021 (org.eclipse.linuxtools.callgraph.feature.group 0.0.2.201009101021)
Software currently installed: Shared profile 1.0.0.1288369199813 (SharedProfile_epp.package.linuxtools 1.0.0.1288369199813)
Only one of the following can be installed at once:
Callgraph Core (Incubation) 0.0.1.201009101021 (org.eclipse.linuxtools.callgraph.core 0.0.1.201009101021)
Callgraph Core (Incubation) 0.0.1.201006152250 (org.eclipse.linuxtools.callgraph.core 0.0.1.201006152250)
Cannot satisfy dependency:
From: Shared profile 1.0.0.1288369199813 (SharedProfile_epp.package.linuxtools 1.0.0.1288369199813)
To: org.eclipse.linuxtools.callgraph.core [0.0.1.201006152250]
From: C/C++ Call Graph Visualization (Incubation) 0.0.2.201009101021 (org.eclipse.linuxtools.callgraph.feature.group 0.0.2.201009101021)
To: org.eclipse.linuxtools.callgraph.core [0.0.1.201009101021]
thanks in advance.
Re: problem installing C/C++ Call Graph Visualization [message #639824 is a reply to message #638637] Wed, 17 November 2010 23:44 Go to previous message
Jeff Johnston is currently offline Jeff JohnstonFriend
This is occurring because you have installed the EPP as root and are running it as a regular user when you attempt to do the update.
You can get around this by either reinstalling the EPP locally as your userid or if you want to have a shared installation, run the EPP as root only when you need to perform updates, then switch back to your regular userid for all other tasks.
Previous Topic:Need o profile plug -in for windows
Next Topic:using the ChangeLog plugin without CVS
Current Time: Wed Jun 20 15:47:21 GMT 2018
Powered by FUDForum. Page generated in 0.01801 seconds
