Home » Eclipse Projects » GEF » How/when to show popup menu on connection creation?
How/when to show popup menu on connection creation? [message #638491] Thu, 11 November 2010 12:59 Go to next message
h1055071 is currently offline h1055071Friend
Does anyone know how to do the following:
When the user is using a connection tool and then clicks on the target
figure to complete the connection I would like to intercept this to
display a pop-up menu so the user can choose an option. Where to
intercept the mouse-down event?
PB
Re: How/when to show popup menu on connection creation? [message #638493 is a reply to message #638491] Thu, 11 November 2010 13:49 Go to previous messageGo to next message
Devi Vara Prasad Bandaru is currently offline Devi Vara Prasad BandaruFriend
org.eclipse.gef.editpolicies.GraphicalNodeEditPolicy.getConn ectionCompleteCommand(CreateConnectionRequest)
Re: How/when to show popup menu on connection creation? [message #638503 is a reply to message #638493] Thu, 11 November 2010 14:07 Go to previous messageGo to next message
Hi, no this won't work because this is called also when the mouse is
hovering over target figures. I need it to activate on a mouse down
event which is called from
AbstractConnectionCreationTool.handleCreateConnection()
PB
Re: How/when to show popup menu on connection creation? [message #638513 is a reply to message #638503] Thu, 11 November 2010 14:42 Go to previous messageGo to next message
What about using a custom creation tool which extends the default org.eclipse.gef.tools.ConnectionCreationTool?
Re: How/when to show popup menu on connection creation? [message #638584 is a reply to message #638513] Thu, 11 November 2010 16:48 Go to previous message
Thanks, yes, this is what I am doing now. It seems to be working so far.
PB
Previous Topic:Scale factor for feedback layer
Next Topic:Implementing Connections in Gef without having a Palette
Current Time: Sat May 26 16:01:49 GMT 2018
Powered by FUDForum. Page generated in 0.02476 seconds
