Home » Modeling » M2T (model-to-text transformation) » [Xpand] Using Xpand programmatically
[Xpand] Using Xpand programmatically [message #638299] Wed, 10 November 2010 18:17 Go to next message
Rafael Angarita is currently offline Rafael AngaritaFriend
Member
Hello, I exported my Xtext projects as pluging and created a new Java project and added the Xtext Nature, so I can write code using the language I defined. Now, I would like to generate source code using the template I defined in my Xpand project.
Unfortunally, I have not had much success in finding documenation and tutorials about using Xpand programmatically, so I am working almost only with the information I have found in other posts. Therefore I am a little bit lost.
In my Java project I created a class with the following code:
        OutputImpl output = new OutputImpl();
        Outlet outlet = new Outlet("xpandOutput");
        outlet.setOverwrite(true);
        output.addOutlet(outlet);
        Outlet outputOutlet = new Outlet("testOutput");
        outputOutlet.setName("OUT_FILE");
        output.addOutlet(outputOutlet);
       // create an execution context
       XpandExecutionContextImpl execCtx = new
       XpandExecutionContextImpl(output, null);
       execCtx.registerMetaModel(new JavaBeansMetaModel());
      org.eclipse.xtend.expression.Resource template =
		execCtx.getResourceManager().loadResource("myTemplate", "xpt");
		 execCtx = (XpandExecutionContextImpl)(execCtx.cloneWithResource(template));
		 XpandFacade facade = XpandFacade.create(execCtx);
		String templateName = "expSpecification";
		List<Object> params = new ArrayList<Object>();
		facade.evaluate2(templateName, targetObject, params);
One of the problems I have is that I am not sure about what the targetObject should be. Also, I don't know in which step I am suppossed to tell Xpand about the file from which the code would be generated.
I would appreciate if someone could help me or show me any tutorial or documentation about this specific proccess.
Thank you very much.
Re: [Xpand] Using Xpand programmatically [message #638307 is a reply to message #638299] Wed, 10 November 2010 18:59 Go to previous message
Darius Jockel is currently offline Darius JockelFriend
Member
you are right, there is no documentation how to use the XpandFacade,
but take a look at this chapter:
5.8. Calling Extensions From Java
Darius
PS: there is another Xpand programmatically thread:
http://www.eclipse.org/forums/index.php?t=rview&goto=638 246#msg_638246
Previous Topic:[MTL] Reading Opaque Expressions
Next Topic:[EMF: Answered] How to create a container of references
Current Time: Sun Feb 18 05:31:42 GMT 2018
Powered by FUDForum. Page generated in 0.01828 seconds
