| Adding DropAdapter causes Widge is Disposed error [message #638207] |
Wed, 10 November 2010 08:59 |
William Koscho Messages: 10 Registered: May 2010 |
Junior Member |
Hi Everyone,
I'm trying to add drag and drop support from a TreeViewer to a GraphViewer (which uses zest).
I have a GraphViewPart that contains the GraphViewer, and inside the GraphViewPart I add DropSupport to the GraphViewer using the following line:
m_graphViewer.addDropSupport(ops, dropTransfers, new MyDropAdapter(m_graphViewer));
The MyDropAdapter class just extends ViewerDropAdapter and contains a bunch of System.out statements to show me what is happening.
The problem happens when I close the application, it generates the stack trace below. If I comment out the line above, and don't add DropSupport, then I don't see the exception. After digging thru the eclipse code it seems like the Display == null where the exception is happening. Since the application is closing, does that make sense? If so, why would I be still getting this exception?
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
at org.eclipse.swt.widgets.Widget.removeListener(Widget.java:921)
at org.eclipse.swt.dnd.DropTarget.onDispose(DropTarget.java:560)
at org.eclipse.swt.dnd.DropTarget$2.handleEvent(DropTarget.java:157)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Widget.release(Widget.java:808)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:446)
at org.eclipse.swt.dnd.DropTarget$1.handleEvent(DropTarget.java:149)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:872)
at org.eclipse.swt.widgets.Widget.release(Widget.java:811)
at org.eclipse.ui.internal.PartPane.dispose(PartPane.java:180)
at org.eclipse.ui.internal.ViewPane.dispose(ViewPane.java:193)
at org.eclipse.ui.internal.WorkbenchPartReference.dispose(WorkbenchPartReference.java:681)
at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1721)
at org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchPage.java:1713)
....snip....
Thanks in advance,
Bill
FUDForum. Page generated in 0.03484 seconds
